Question about Speed Queen AWS52NW Top Load Washer
BELT REPLACEMENT HELLO, WE HAVE A SPEED QUEEN WASHER MODEL #SLW33ORAW. WE REPLACED THE BELT. WE ARE NOT SURE IF IT IS ON CORRECT. WHEN WE TURN ON THE WASH MACHINE ON SPIN CYCLE THE MOTOR TURNS BUT NOT THE BELT. THER IS NOT ANY EXCESS SLACK IN THE BELT. IS THERE A VISUAL DIAGRAM FOR THE BELT PLACEMENT? DO YOU HAVE ANY OTHER SUGGESTIONS?
  • philipv Sep 02, 2008
    I have replaced my belt and my cycle stops and the moto keeps on spinning. Can you please help
    President:
  • 1,314 Answers
Look real close in the tub holes to see if a small object like a nail or screw is jamming it then try to turn the tub by hand and let me know the results
Posted on Dec 30, 2007
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
Repair a belt on a washing machine for a speedqueen
Remove the front panel by removing the three screws at the bottom of the panel and then tilting it up to unhook it at the top. Make sure the machine is disconnected from the electrical power - not just switched off but unplugged at the socket. Look for the belt between the electric motor and the main drive pulley of the agitator and also locate the belt tensioner which is a small pulley pressing against the belt under tension of a spring hook onto it. Pull and keep the tensioner away by hand to allow the removal of the belt starting at the motor pulley. Replace with the new belt by starting at the agitator pulley. Keep the tensioner pulley out of the way until the belt is fitted on both pulleys and then allow it to settle against the belt again. Do not adjust the spring tension and buy the correct belt from speed queen as it requires a graphite type belt. An ordinary vehicle v-belt will not work - repeat will not work. Replace the cover by hooking it in first at the top and then replacing the screws at the bottom.
Oct 19, 2014 | Speed Queen Clothes Washer Agitate & Spin...
Speed Queen model no.AFN50RSP111TW01 Washer makes humming sound all the time in off position,i am being told by dealer that its the transformer which is normal,replaced transformer and still hums,unplugged...
Usually a transformer hums when it does not have the proper voltage being supplied to it. I would check this first. If the voltage is correct contact a parts supplier and request a new transformer. Speed Queen has a great parts warranty. As Speed Queen is really a commercial machine it is not unusual to have them make more noise than other manufactures.
Dec 18, 2010 | Speed Queen ATS90AWN Front Load Washer
WASHER VERY LOUD AFTER I REPLACED DIRECT DRIVE PUMP
No... I work speed queen all day long and I know they can be loud. Just double check and make sure the washer is sitting level. But other than that speed queen washers and dryers are just very heavy duty work horses.
Apr 08, 2009 | Washing Machines
Kelvinator or (Speed Queen Top Load washing machine)
You probably have the wrong belt, and its to small? Go to repairclinic.com or google Kelvinator parts. Order the correct belt.
Apr 15, 2008 | Speed Queen AWS52NW Top Load Washer
Speed Queen HD comercial washer
Its sounds like you need a replacement knob, if you can turn the disc behind it to start a cycle and the machine times out find the timer is probably still good, do a Google search for Speed Queen parts, and buy the correct replacement knob.
Mar 30, 2008 | Speed Queen AWS52NW Top Load Washer
Belt
We'll assume no problems with the belt installation - the tensioned idler pulley is pressing against the belt etc.
You didn't say whether it drained out OK or specify what model but it sounds like the brake is stuck or there's something caught in the basket. Try turning the main drive pulley (the one in the middle) Even with it full of water it should turn freely. Take the tub top off and check for foriegn obects stuck between the basket and outer tub. A wire coat hanger works well fro this.
Jan 04, 2008 | Speed Queen AWS75NW Top Load Washer
Speed Queen wash machine
may be incorrect belt or gear box locking up.
Speed Queen AWS52NW Top Load Washer Logo
372 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
