Question about Dell Inspiron 1100 Notebook
Notebook not starting and screen remains blank.
The laptop starts makes some noise but seems to stop. The Numlock LED flashes but screen is blank. The fan appears to remain on and other lights are on as well. Any idea what could be wrong? Do I have a dead CPU? I took the RAM out and it gave 3 beeps but nothing showed on screen. IF it was a bad CPU would the screen still show? Or do i have a dead mobo?
  • Anonymous Apr 15, 2008
    i cant type without eeeeeeeeeeee filling up my screen i hold down the backspace button in order to type. please help
  • Mouin Aboulhosn Dec 01, 2008
    The issue is that the laptop appears to have gone into stand-by and
    will not wake up. It is getting power and appears to power on but will
    turn it's self back off again
    Scholar:
  • 68 Answers
Is the light flashing for 10 seconds and then shutting the laptop back down?
This could be a number of things. 1. The memory needs to be re-seated in the motherboard (or it is bad) 2. The battery is bad.
If reseating the memory does not take care of the problem, remove the battery and power up the laptop on just the AC adapter (power cord). Once it comes up, you can put the battery back in, and hope that it takes a charge. You can get a replacement battery for pretty cheap online. That has fixed most of them I have had to deal with.
Good Luck! James
Posted on Dec 04, 2008
    Sergeant:
    Champion:
  • 310 Answers
This will be easer than you think.
first unplug power cord,pull out your battery and test it by pushing the button on the battery. It will be dead. leave it out. plug in power cord, nothing should work. test your power cord. if nothing than test lower on the cord it might be the plug in that plugs into the laptop. what happens is the battery get to low and the lappy goes into a safe mode . you will need a charged battery to get it to boot.
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Dec 30, 2007
Ibm thinkpad R31 won't start
your board are faulty and require for repair, try call the warranty or send for hardware repair
Nov 12, 2013 | IBM ThinkPad R31 2656 Notebook
Blank screen
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jul 03, 2012 | Toshiba Satellite L505D-LS5010 Notebook
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Dec 01, 2011 | HP Computers & Internet
BLANK SCREEN ON MY hp compaq nx9420. my laptop was working fine and then when restarted I got a blank screen. The power LED and cahrging LED both light up but screen remains blank. have changed the video...
Did it display any video at all with boot options or HP logo? Any POST test or beeps after you started the laptop?
Try removing the power ac adapter and battery. then only boot it up with just the AC adapter (no battery).
Good Luck, JAJ
Mar 30, 2010 | HP Compaq nx9420 Notebook
My ACER netbook turns on but the screen remains
After switching off the aa1, when trying to turn it on again, it just shows blinking leds and the fan is turning. But the screen remains black.
If your aa1 does like this probably its BIOS has been damaged...
Luckily the Acer Aspire One has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore.
Please note that the process I'm about to describe is only meant for emergencies and may void your warranty, so use at your own risk.
1) Format a USB memory key with the FAT mode.
2) Download the latest version of the BIOS from Acer support website:
3) Extract the files from the zip and put both the FLASHIT.EXE and the BIOS file in the root directory of the memory key.
4) Rename the BIOS file to ZG5IA32.FD and then remove the disk.
5) Turn the AA1 off, insert the battery and connect the AC adapter.
6) Insert the USB Memory Key into one of the USB port of the Aspire One.
7) Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on.
8) Release Fn+Esc after a few seconds, the power button will be blinking.
9) Press the power button once. The AA1 will start the BIOS flash, do not interrupt for any reason. After some minutes the power button will stop blinking, and then the AA1 will reboot. Wait till the AA1 has completed all this operations.
If everything has gone right, the BIOS is flashed and all settings are reset to default.
Nov 16, 2009 | Acer Aspire One Netbook 8.9" Notebook
When i switch on the my thinkpad it starts to boot up then the screen goes blank the battery light goes orange and and flashes and it makes a cranking noise.
Is the Battery making the cranking noise? If so the battery is telling you the battery is dying. I have a IBM ThinkPad 380Z and when on the charger it makes a beeeeep noise and goes off and on for almost the entire day and then stops and keeps a solid orange battery light on.
Try booting without battery
Feb 23, 2009 | IBM ThinkPad T40 2373 Notebook
When i turn on my laptop, the screen is blank
It seems to be u have problem with ur RAM ..Try to change it
Nov 29, 2008 | IBM ThinkPad R40 2722 Notebook
Dell Inspiron 1100 Notebook Logo
194 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
