Sony wide screen projection tv model kp46wt510
The picture is multicolored and is bowed at the top and bottom, how do you fix the above problem.
  • 2 more comments
  • TAC62 Jan 02, 2008
    Picture is bowed and colors and images duplicated as if shadowed. How do you repair?
  • Anonymous Dec 18, 2008
    I have had the same problem several times. Changed the conv. ICs and one protection on the power board but after a while the same happened again. now i can not see the colour of resistors in front of IC's, What is the value of these resitors? are they all pralell conected ? for what reason this happen?
  • bigdog3162 Jan 16, 2009
    Sony model KP-46WT510 - just moved, hokked up TV and noticed red crosshair lights in the convergence adjustment are way off. I can move them some via adjustment process but they reach end of adjustment range before lining up with white crosshairs. Is one of the three lamps inside a red one? Is it possible to manually adjust this lamp so it falls into a closer range? What do I do? Saw previous posts, what is an IC?
    thanks
    Rob
  • Anonymous Apr 10, 2009
    WHERE IS THE ICS LOCATED, AND CAN I DO IT MY SELF?
    Novelist:
    Champion:
  • 232 Answers
Hi, replace the convergence IC`s and any discolored resistors in front of the IC`s, and you`ll be good as new, BMW Rider
Posted on Dec 30, 2007
My flat screen tv has a multicolor bar running down the middle from top to bottom, how do I fix this?
you can fix it by going to tv colour changing option otherwise you read the catalogue.
Mar 27, 2013 | Insignia NS-24E730A12 24" Class LED HDTV
Center bow on picture top and bottom with 1" black showing
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba TN55X81 55" Rear Projection...
Tv picture has a top and bottem bow to it and picture seems to be too large as some stuff on the outside of the picture just gets cut off.
Replace your Regulator IC mounted on Board above bottom Bottom boards STK730-010 Call Mats for Part 1-800-628-1118
Sep 26, 2009 | RCA P52937 52" Rear Projection Television
Colors have separated. and top and bottom af pictures are bowed. i have a sony kp-46s55. its about nini years old and it was free. currently the colors are separated and the top and bottom of the pict
nbad convergence ic , this need to be done by a profecional tv tech , because need to check for the pico fuse and resistor around the area
May 08, 2009 | Televison & Video
Cheap Fix?
I will strongly advise you to replace the two STK392-120 as a pair. and this will cure your bowing picture problem. You may need to re-converge your set. best of luck.
Nov 05, 2008 | JVC AV-48WP30 48" Rear Projection...
3d picture
multicolored 3d effect is a problem with what is known as convegence... ussally there are two large chips (ic) that blow. gennerally they have to be replaced mabe some fuses and resistors..
May 02, 2008 | Samsung HCL4715W 47" Rear Projection...
Rca tv r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
rca t v r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
Apr 05, 2008 | RCA Televison & Video
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Bowed picture
malfunction of the pinchusion circuit.check pinchusion diode and transistor and pincushion ic
Dec 23, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Televison & Video Logo
623 people viewed this question
Top Televison & Video Experts
