After PGE replaced the electric meter outside, the computer doesn't recognize the mybook. I have misplaced the software (if it came with any can't remember). What can I do?
The meter replacement shouldn't cause hard disk recognition problems. If it powers up, it should be recognised and need no drivers, since it's a standard USB block device, supported natively by XP and later, Mac OS and most Linux distributions.
Why did they had to replace the meter? If anything odd happened to the electrics, it may well be that the MyBook got its electronics damaged. In that case you won't be able to access your data directly: you'll have to extract the hard disk from its plastic enclosure, and place it into another, intact USB enclosure (any enclosure will do, basically. Only verify whether it's a EIDE disk - four big power pins, 2-3 inch rectangular data slot with lots of pins - or SATA - two small slots vaguely L-shaped, about 1 inch wide - and get the appropriate type of enclosure).
How come my Western Digital 1.5tb wont work with my ps3 using the USB, I have a 80gb Western Digital...
(More)
How come my Western Digital 1.5tb wont work with my ps3 using the USB, I have a 80gb Western Digital that works fine
The files will not transfer from Real Player SP to the external drive, although the external drive...
(More)
The files will not transfer from Real Player SP to the external drive, although the external drive is only 23% used. How do I fix this? A Window comes up and says, "[Number of files] cannot be moved." They always could previously.
My old computer died,but fortunately I had "My Book Essential 160G" plugged in. Now with...
(More)
My old computer died,but fortunately I had "My Book Essential 160G" plugged in. Now with my new computer with the "My Book.." plugged in it is not copying my work. Did I ever have a disc for it, I don't remember. Is there one for it that makes it copy? If not, what do I do? Is so, where can I get another? thanks from a 76 year old dumby.
sony ps3 hard drive replaced with a western digital 320gb hard drive... screen says hard drive not...
(More)
sony ps3 hard drive replaced with a western digital 320gb hard drive... screen says hard drive not recognized
My computer is recognising video files on my harddrive as audio files even though the properties of...
(More)
My computer is recognising video files on my harddrive as audio files even though the properties of the files on the harddrive show that they are saved as video files.this happens on windows media player I cant get them to play with real player at all.
