Question about Nextar MA834-2P MP3 Player
How to turn on my mp3 player
It has a play button and a volume button and a hole for headphones and a mode switch. I have held down the play button and it didnt turn on. How do i get it to turn on?
Check to make sure that the plastic is off the battery. Its one problem i've seen people running into. There is a plastic film around the battery that comes with the player.
Posted on Jan 01, 2008
Can decrease volume down, but can't get it up. now i barely listen the music playing on it. afraid to press volume decrease button
The problem is, is that there is a shortage in the headphones. When a headphone shorts out it can have your problem, or it can get really stadicy. If it's the player itself, then... This is a hard thing to solve, but if the volume button's are sticky then that would explain the turning lower part. What i see here is that there is the 1. Internal problem 2. The person's fault and 3. The manufacture's fault. I can't explain how many times i have had to send in my Mp3 Player in for it's warrenty becuase of that same problem.
Oct 30, 2010 | Oakley Thump MP3 Player
Stuck in lock mode and cannot turn it off, help please.
I held the menu button down for approx one minute and the unit rebooted itself.
Jul 21, 2010 | SanDisk Sansa e250 MP3 Player
GC-822 Buttons Just Change the Color
After a mode is selcted by moving the mode slider switch left or right then depress that same mode slider switch like a button. When the mode switch is used to change a mode but one does not press it in to select it, that is when the play button changes colors.
Sep 20, 2009 | Sears GC-820 MP3 Player
Hardware wont install
I had the same problem with my e260 4GB player. To upgrade the firmware to enable setting USB mode to MSC, try the following;
1. Slide the hold switch to the locked position by sliding switch at the top of the player towards the headphone jack until you see the orange indicator.
2. Press and hold the << (rewind) button.
3. With the << button held down, connect the player to the PC.
Once I did this, the firmware was upgrade, the USB Mode command was available in the Settings. I switch to MSC, plugged in the player again, and now Windows recognozes it.
Nov 28, 2008 | SanDisk Sansa e200 MP3 Player
My Creative Zen has a white screen but syill plays music
1. Fully charge the unit
2. Get a song to play
3. Lock the device
4. Wait for black screen and leave it like that for 20 seconds
5. Hold the play/pause button down and move the side switch out of lock mode, then push all the way down (like you're turning it off) and release (back to middle position)
6. Release the play/pause button
Sep 19, 2008 | Creative Labs Zen Digital Media Player
Zen stone mp3 player not switching on
Mine was also completely dead, with the reset doing nothing! I held the vol+ and the Play button at the same time and it was good to go. Holding just the play button or the vol+ button didnt acheive anything. But as I held both together, It came back to life instantly and I havent had any problems with it (for a week so far).
May 08, 2008 | Creative Labs ZEN V Plus MP3 Player
Why won`t my mp3 take itself off hold?
Power & Hold switch
Slide and hold in the opposite direction
of the arrow for power on/off.
Slide in the direction of the arrow to
lock the button functions.
If that fails,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 15, 2008 | Samsung YP-T10 Digital Media Player
Recovery mode
to switch to recovery mode flick the switch on the top towards the headphone jack (so you see the orange), then hold down the REC button on the side, and plug into you computer. KEEP IT HELD DOWN UNTIL THE PLAYER IS RECOGNIZED! the player will be recognized by dif name. you are now in recovery mode.
What i suggest you do is to look at this video on how to format your player...all data on it will be erased (like songs and videos) but it will be worth it!
NOTE: these are for when the player is in MSC mode
For Windows XP
For Windows Vista
I did this for my player and now it works fine!!!
Mar 12, 2008 | SanDisk Sansa e250 MP3 Player
Delete or reset a wrong firmware file for IVO- m600 mp3 Player (Rockchip)
This is how to get into update mode,
All you do is this,
1) Switch the player OFF using the main on/off switch.
2) Hold down the "MENU" or the "PLAY" button and keep it held down.(try the other buttons if these dont work)
3) Connect the usb to the player.
4) Wait for about 10 seconds before releasing the button.
5) You should be now in "ROCK USB" upgrade mode
6) Then just start ConsumerUpdate and upload your firmware.
Nov 18, 2007 | Audio Players & Recorders
Creative Labs Nomand Jukebox Zen Xtra
Zen Nomad Xtra - to go to Rescue Mode do the following:
1. Insert a pin into the small hole on the left side of the player
below the volume adjustment switch.
2. Hold down the Play button on the right side of the switch
3. Rescue Mode Menu will appear
4. There are 4 Options available, but best option to fix most
problems is reformat hard drive.
5. Reformat is very fast
6. Turn off and reboot.
7. Problem solved.
Oct 31, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Nextar MA834-2P MP3 Player Logo
46 people viewed this question
Top Nextar Audio Players & Recorders Experts
Robert Graf
Level 1 Expert
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
