Question about Compaq Evo N610C Notebook
Unusual Blue tint on LCD
Dear Experts,
I have some unusual blue tint on complete screen of my LCD of notebook. It started few days back .Some time it goes off with some flickering and every thing becomes fine. But now it is there for all time.The LCD is working fine only it annoys with this blue tint and i could not watch movie or picture with this. Please help how can I fix this.
  • abbasbw Dec 31, 2007
    I tried to open the LCD but after opening the four screws at the bottom of the panel I was stucked as I was unable to open further as I was scared to break the front frame. Kindly help in guiding to open perticularily the LCD of EVO n 610 c
    Master:
  • 619 Answers
Something wrong connection inside video system lose wiring or plugs.
Posted on Dec 30, 2007
42" plasma. Why did it just start showing a blue tint on the bottom 1/4 of the screen?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma &LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jul 30, 2015 | Emerson Televison & Video
Hi every time i turn the computer off...the monitor stays on with bright blue colour on screen....then when i try to turn on the computer back on the monitor stays the same and wont show windows...
Obviously geikalok is retarded and doesn't know the difference between a monitor and a printer.
You have a vary unusual symptom. What happens when you change the resolution of your computer to match what the monitor can do? It should be able to handle 1920 x 1200 so I doubt your resolution is too high. Unfortunately I think you may be having a problem with your main board, and there is also a slight chance your power board is going bad (which can sometimes cause some unusual symptoms). You first should check to make sure the unit is no longer under the 3 year warranty (if it is, go to viewsonic.com). You can open the unit up and check the power board for capacitors that are bad but that is unusual in this model, although the power board going bad from other causes is not unusual in this model. You can measure the power voltages on the power board, but if they are OK then most likely you will have to have the main board replaced. I would recommend contacting Viewsonic.
Aug 14, 2010 | ViewSonic VX2835wm Monitor
I unplugged my Acer al1914 monitor from my computer and plugged a different acer al1914 in my computer and now when I transfer the screen from notebook to monitor it has a blue tint on the entire screen. I...
Check the color settings in the on-screen menu. You can choose between "Warm", "Cool" and "User". Maybe you used the "Warm" setting before and somehow it got changed to "Cool".
If this is not the case, you can try the "User" mode and reduce the intensity of the blue channel.
If even black areas show a blue tint, maybe running an auto configuration from the menu helps.
As a last resort, use the "Reset" menu item which resets all settings to factory defaults.
Mar 30, 2010 | Acer AL1914 19" LCD Monitor
I get sound but no picture
If the screen went dark blue, this is the way that sets mute the video to protect the tube. However If the screen is very bright blue with possibly blue lines going through the screen, either the blue gun in the CRT has failed which is unusual but can happen or the driver transistor/IC which drives the blue gun has gone short circuit. If you know how to use a meter, you can perform a comparison check by comparing say the red O/P TX with the blue O/P TX. Ian
Jul 23, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
POWERING ON
good day
since it is unusual, have it checked by a competent technician. it may only be a simple reset but nevertheless at least you wont be bothered again by that problem
Oct 09, 2008 | Sylvania LC260SS8 26 in. LCD Television
My acer aspire4310 notebook suddenly displays a white screen
If you have blue strip running down vertically from top to bottom then normally there is a problem with LCD or a loose LCD cable.But what I recommend you to test more is tha,t if you tab at the back of your screen ...does this problem occur ???
Incase it does,then its a loose LCD cable problem.You still need
a qualified person who knows how to open the monitor to repair inside.
And again for the White screen it can also be both cases I mentioned above
ByeBye,takecarfe
Apr 22, 2008 | Acer Aspire 5610-4648 Notebook
Sony KP-51WS500
does it have blue video image?
Sep 29, 2007 | Sony KP-51WS500 51" Rear Projection...
Compaq Evo N610C Notebook Logo
265 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
