Question about Sony MHC-GS300AV CD Shelf System
Press Power Protect
When I turn on my stereo Press Power Protect flash on the display, how do I fix this problem?
  • Sony Master
  • 1,550 Answers
Always be solved replace him the audio amplifier IC
Posted on Feb 11, 2009
My Sony home theater DZ290K had a push power protection on the display screen how can I fix it?
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
You may also refer to the following link for additional troubleshooting steps.
PROTECT and PUSH POWER flash alternately on the amplifier screen
Aug 26, 2015 | Sony Audio Players & Recorders
My JVC car stereo display " Protect " on display
How to change clock on Pioneer cxc5719 car radio?
1 Turn the ignition key to On or Accessory. Pull up the emergency brake. 2 Press Source or Power to turn the Pioneer car stereo off. 3 Press the Clock button to display the time. 4 Press and hold the Function or Audio button for 3-4 seconds. The display will come on, and the hour should flash. 5 Use the Up or Down buttons to change the hour setting on the stereo. 6 Press the Left or Right keys to get to the minutes. When the minutes start to flash, press the Up or Down keys to set the clock to the correct minutes. 7 Press the Function or Audio button again to exit.
Mar 25, 2011 | Car Audio & Video
My stereo says" protect" everytime i turn it on. can't get anything else.
Hello grammagrisbo, hi your Kenwood head units will show "protect" when there's a problem with the speaker outputs so check to see if the impedance load meets your radio, 8ohms or 4 ohms?. having parallel two speakers on a single channel may cause this dilemma. This might also mean a shorted speaker wire, a blown speaker, or an internal defect in the head unit. Once the condition that's causing the "protect" mode is fixed, the CD player should be back to normal, the next time you turn it on.
If it's staying in "protect", then you'll definitely have to remove the stereo and do something to fix it. Many car audio stores will do system troubleshooting, for a fee. If you want to do it yourself, here's what you need to do:
Pull the Kenwood unit from the dash and disconnect all the speaker wires. power it on and see if the "protect" message displays. If it does, the stereo has an internal defect and will need to be serviced. If it doesn't, then turn it off, and re-connect one speaker only. Turn it on again and see if it will displays "protect" message.
If the radio works with one speaker connected, connect the other speaker to the second channel, you may have now the idea where the problem begun, you will identify the speaker that's causing the problem. There may be a wiring problem or defective speaker in that channel.
If it displays "protect" with a single speaker connected, then disconnect that one and try the other one. If all the speakers cause a "protect" mode, then you're probably back to a defective head unit.
Aug 31, 2010 | Kenwood Car Audio & Video
protect mode means some speaker wires somewhere in the car are grounded out or are crossed... find the short and it will fix the problem. try testing all of the speakers one by one from the wiring harness... you'll find the problem. Good luck.
Nov 30, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
Sony LBT W5000
According to Page 46 of the LBT-W5000 Operating Instructions:
"The display stars flashing as soon as you plug in the power cord even though you haven't turned on the system (demonstration mode).
Press DISPLAY (for LBT-W5000 / W300 / XB700 / XB500) or DEMO (STANDBY) (for other models) while the system is off. If the system is in the Power Saving mode, press POWER SAVE / DEMO (STANDBY) (for LBT-W5000 / W300 / XB700 / XB500). The demonstration appears automatically the first time you plug in the power cord, or if there is a power outage lasting longer than half a day."
I tested this today, as my LBT-W5000 was in Demonstration Mode. It definitely works. The only catch is (at least on the W5000), and it's a minor one, you have to reset your clock afterwards.
May 29, 2009 | Sony LBT-W5000 Shelf System
protect display on my sharp mini component system, how do i fix this problem
Feb 21, 2009 | Sharp Audio Players & Recorders
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Protection displayed and shuts off
The protect message indicates that the output amp section has a problem. Normally this requires the replacement of the output transistors or the output amp pac. Expect the repair cost to be about $20-$60 for parts plus the local labor rate.
Mar 22, 2008 | JVC HXC6 500-Watt Stereo System with 5-CD...
Protect mode
Hi ,
Does your unit go into protect mode without speakers connected?.
Jan 26, 2008 | JVC HX-D7 Shelf System
Sony MHC-GS300AV CD Shelf System Logo
288 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
