Question about SanDisk Sansa e200 MP3 Player
"Load main image failed
Best Solution posted on Apr 04, 2007
I have also encountered the same problem.
Switch to Recovery Mode"
What I did was:
1. Download and install the Firmware Updater Software from SanDisk "http://www.sandisk.com/Assets/File/Downloads/firmware/SansaUpdaterInstall.exe"
2. Bring up the Sansa into recovery mode by:
-Switch the Hold Switch to Locked Position
-Hold (and continue to hold) the Record button
-Press the menu button (may a need an extra hand) while plugging in the USB Cable to the computer
3. After the Sansa is in the Recovery Mode saying:
"... Enter 2.0 MSD" (Means that it is currently in MSD)
4. Right Click on the Sansa Firmware Updater icon in the System Tray (near the clock) and select "Update Now"
I have tried the above steps but after right click on the Snsa Firmware Updater icon in the System Tray I got the option as 'Check for Update Now' instead of "Update now" and then click on that option i selected Japan option i did not got Finish option. now i am getting the same message 'Load main image failed switch to recovery mode" plz help me out.........Thanks in advance....
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
When i start appear "load main image failed switch to recovery mode"
The error means that the program of your SanDisk is corrupted. Do you see an option to switch it to "recovery mode"? If not, the best thing that you could do is to send the device to the authorized service center for repair.
Thank you!
Sep 12, 2010 | SanDisk Sansa E280 MP3 Player
Sansa 260 R load main image failed message
The Sansa e260 Rhapsody could be recovered by resetting the player.
How to reset the player :
1. Player switched on.
2. Press and hold the power button for approximately 30 seconds.
3. Put the player back on.
When the fault is not resolved a firmware update / reinstallation needs to be made. There are 2 steps needed for getting new firmware on the player.
Step 1: switching the player into recovery mode / MSC mode
1. Turn off the player.
2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
3. Press and hold the REC button and connect the device to the computer.
4. A message will appear on the device display screen confirming the connection and a memory partition will be viewable in My Computer.
5. Release the REC button.
Step 2: Update the firmware ( updating firmware always in MSC mode, see Step 1 )
Use next link for updating the firmware:
http://kb.sandisk.com/app/answers/detail/a_id/306
The Sansa updater installation on the computer should be the easiest way to update firmware.
Need more help ? Just post a comment.
Dec 17, 2009 | SanDisk Sansa e260 MP3 Player
Recovery mode?
i havent encountered that specific problem, nor have i seen an option for recovery mode. My best suggestion is to go to the source and download again. http://www.sansa.com/support/sansa_e200/faqs look to the right hand side for download options.
Jul 14, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e200 load main image failed
i'm thinking that it has too much info on it, so it ets stuck when you turn it on.
Jul 31, 2008 | SanDisk Sansa e260 MP3 Player
Load main image failed Switch to Recovery mode
Use the Sansa Recovery Tool on the Sandisk website
Jun 01, 2008 | SanDisk Sansa e250 MP3 Player
Switch to recovery mode...
go here
good luck
please mark the post with a fixya!
Feb 12, 2008 | SanDisk Sansa E280 MP3 Player
Recovery mode
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Oct 02, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
60 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
