Question about JVC RX-D301S Receiver
Getting no audio to game systems, pc connect won't connect
First, I'm trying to hook both a Wii and an Xbox 360 up to this JVC RX-D302B receiver. I'm running the 360 through the dvd/dvr inputs and the Wii through the vcr inputs. I have a video cable running from the monitor output to my tv to complete the circuit. I get a video signal from both inputs, so my tv has a clear picture, but no sound is being output from my speakers. Anyone know what's going wrong there?
Also, probably unrelated, my USB transmitter won't link up with the antenna supplied with the receiver, so the pc connect feature is currently unavailable to me.
  • 1 more comment
  • Landgrafb Dec 30, 2007
    Correction: I'm using the JVC RX-D301S receiver.
    Additional Update: After messing with settings and such, I managed to get audio and video to things plugged into the dvd/dvr input by tuning to the dvd multi in input. Do I just have a buggy receiver?
  • Landgrafb Jun 14, 2008
    Thank you very much for the help :)
I also had the same problem when using my optical output for DBS and DIGITAL DVR/DVD.. you need to change the setting for this by on the remote changing to either analouge..rca sound input or Digital...for Optical input. The same problem cuaght me oput for a long time as well. The button is when you slide down the remote cover and the button is called analoug /digital
Posted on Jun 14, 2008
Trying to hook up tv to JVC RX-315 and not sure what to hook up where
Hi,here is my simple solution...
If you want to listen your TV on your Stereo system thru your receiver,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on RECEIVER corresponding your RCA or Optic connection..
There you go..Your TV sound is on the Receiver..By this means whatever you watch on the
TV (
tuner, satellite , Xbox ) ,it's sound will come thru your stereo..
Hope this helps!
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 24, 2011 | JVC Audio Players & Recorders
RX-V465 output HDMI 1 will work but HDMI 2-4 won't, also when I hook up Wii via rca to receiver only get sound no picture.
This receiver has only one HDMI output, but 4 HDMI inputs. If some inputs don't work, try connecting the equipment (DVD for example) to HDMI input which works with other equipment....
For the RCA (composite) video input - it won't work, because this receiver don't have any video processing circuit.
So HDMI input video goes to HDMI outout connector.
Composite (RCA) video input goes to Composite outout and no other video output.
S-video input goes only to s-video output.
Dec 20, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
I have my xbox 360 connected via hdmi to my yamaha rx-v363 receiver, and the receiver connected to my sony bravia lcd tv via hdmi as well. The xbox picture comes through to the tv fine, but the sound will...
Connect Xbox via HDMI to DTV/IN, Connect HDMI from out to Sony Bavia's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
2X HDMI cables and one Optical are required.
Enjoy great sound :)
OH: choose the DTV input then stereo and then dolby 5.1 etc .. cheers
Sep 04, 2009 | Yamaha RX-V363 Receiver
I need to connect my Dish Network 625 DVR to a JVC RX-709VTN surround sound receiver, along with my DVD and VCR. Nobody can help me at Dish Network. Seems they aren't trained to help outside of the DVR. I...
Providing you have enough input ports on the surround run you a red and white audio RCA jack from the receiver out port for TV1 and connect to the same colored ports on the satellite in ports on the surround. If you do not have enough ports then you may have to use the in ports on the DVD etc to run the TV through to utilize the surround system. Thanks for using Fix Ya.
Apr 07, 2009 | DISH Network ViP622 DVR DTV Receiver /...
No picture from wii
The RX-V800 switches the various video signal types separately.
Since you are feeding S-Video to the TV the composite (yellow) input from your Wii is not going anywhere.
If you cant get S-Video output from the Wii then I'd suggest a simple Composite to S-video adaptor plug ($5 say). It worked for me with a Game Cube.
Mar 19, 2009 | Yamaha RX-V800 Receiver
Had the same problem- but had success when I connected the wii to my DVD player, which then HDMIs through the reciever and then HDMI to my projector.
Dec 25, 2008 | Yamaha RX-V661 Receiver
I have the HT-S3100 model, and hooked up my tv, xbox360, and Wii to it. The audio works for all three, but the only video I can get is for the xbox. I am using the component hookup and it is hooked up...
On all tv's there should be independent input for all devices. Xbox 360 ,Wii, and tv. Take a look at input at the back of tv. The Xbox input should coincide audio/video. The same with each device. Then you use the tv's remote to select the input for each device. They should all work independently from each other. Such as component 1 for Xbox, component 2 for Wii, and depending on what type of tv input you use, such as coaxial, RCA, you note and put tv input setting on the device that you are going to use. If you have the audio working on each device, check the video input for each device. Make sure they correspond.
Oct 13, 2008 | Onkyo Audio Players & Recorders
XBOX 360 to JVC RX 5060b
does your reciver have video ins and outs monitor out u have to send master video out from jvc to tv 1st u know im open for chat
Jan 06, 2008 | Audio Players & Recorders
Setup configuration
Have you tried to? I would need to see a wiring block. unit to unit, labeled at each unit including the monitor. I'll bet you can do what you seek to acheive..Give me more info, I'll show you how to do it.Just a list of makes,models,serial #s. If you have all this in PDF files, shoot 'em to me.I'll draw thr lines for you.
Dec 30, 2007 | JVC RX-D301S Receiver
Not getting digital sound from dbs or dvd
try all the possibilitys of connecting cables between the outputs & inputs exept the ones that r allready working maybe theres a wrong connection inside the reciver windman
Oct 16, 2005 | JVC RX-D201 Receiver
JVC RX-D301S Receiver Logo
181 people viewed this question
Top JVC Audio Players & Recorders Experts
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
