Question about Canon SPEEDLITE 580EX TTL Flash
I used the the canon 430 ex flash and now my pop up flash does not work? I removed the 430 and tried to shoot easy mode but no flash HELP!
    Problem Solver:
  • 11 Answers
All Canon EOS cameras with a pop-up flash built-in (digital or film) has a small switch on the flash shoe on the top of the body which tells the pop-up flash not to pop-up when an external flash is mounted on the top. The shoe of the flashunit pushes this switch down to tell the body it's there.
This switch is probably now struck in the 'down' position hence the pop-up flash still believes a flashunit is mounted on the top.
If you hold the camera as if you taking a picture & look underneath the left side of the body's flash mount, you should see a little pin rising up from the body & resting on the sprung part of the metal shoe cover. If this pin can not be seen then there is your problem.
Sometimes it is just a bit of dirt holding it down - sometimes it has almost corroded itself in there.
If you can, try lifting out the metal cover on the shoe (lift the front part infront of the largest contact & pull it backwards) & then try to gently raise the pin. On most models it is plastic & can be easily damaged so be alittle careful with it.
If you can get it moving up & down again, all should be well.
If it's really stuck, then it has to go to a repairer but there should be one who could do just the pin fault without charging for a complete service. (like myself but I'm in the UK)
Hope this helps
Posted on May 09, 2008
    Champion:
    Scholar:
  • 216 Answers
What camera is the 430 parked onto?
Posted on Dec 30, 2007
Hello, I have a Canon 350D, Digital Rebel XT. For some reason my flash will not pop up, and when I manually push it up and try to take a picture, it won't flash. Does anyone know how to fix this type...
Okay there is a fix for this but it requires slightly removing the hot shoe. The camera thinks there is an accessory in the hot shoe therefor will not pop up. The fix for a qualified repair person is simple and it's fairly inexpensive however, that said if you don't know what you are doing then you could burn out the flash circuitry. Yes an external flash will work and give you much better performance then the internal flash, when getting a flash make sure it's an EX type to properly sync with the new TTL and I-TTL flash.
Jan 12, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Flash will not close on Canon EOS 7D
All you need to do is set the camera to shutter priority other non-automatic mode, hold the flash shut and hold the flash button next to the lens opening. You'll hear a motor and a click and it should latch shut.
Jan 30, 2010 | Canon EOS 7D Digital Camera
My xti fell with the 430 ex II attached now it
The hot shoe was bent slightly causing the flash contacts to not touch those of the camera. By using a socket from a socket wrench set, place it over the grids of the hot shoe and tap firmly with a hammer to straighten it.
Jan 02, 2010 | Canon Speedlite 430EX TTL Flash
My Canon Ixus 430 does not take pictures although the
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Nov 24, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Pop up flash Pops up but does not flash
Sounds like the internal flash is broken. I have seen used cameras advertised with this condition so it is not uncommon.
Aug 23, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Speedlite 580 EX II
is your master flash set on a camera? The EX II has something that makes it have a 1 second delay when using sync mode, unless the master flash is set on the camera.
Dec 27, 2008 | Canon Speedlite 540EZ TTL Flash
Built in flash problem
most likely you have set the camera to the auto mode and you are shooting in a place with plenty of light.
your camera has a sensor which activates the flash when needed.
you can set the camera to the manual mode so that you can chose the flash to work even in the day.
Aug 11, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon 430 EX flash problem
Were you indoors? if so, take the ISO of AUTO and out it on 400. Leave the camera set like you had it, Manual 1/60 @ 5.6. Do notuse evaluative metering. Use single spot metering or the smallest center weight setting.
Jun 28, 2008 | Cameras
Canon SPEEDLITE 580EX TTL Flash Logo
75 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
