Recently my 50XBR800 started to turn off, standby light starts to blink for 30 seconds then turn on again. After maybe 1 minute it goes off and then comes on again I bought it 2003 and never replaced the lamp.
Lamp light doesn't lit and stanby light blink 31 times before it turn back on. I unplugged the unit turned bank on but it still have the issue.
Any suggestions?
after replacing bulb it is working fine. I purchased just the blub cost 169 from dlp lamp sourse and got the original bulb.
Thanks
Mine does the same thing but I just replaced the light that is when it started doing i any suggestions
turns off and the standby light blinks for 30 seconds or so and the turns back on. I have changed the bulb twice it works fine for a month or so and then starts up again.
WHEN TURNING TV ON STAND BY LIGHT FLASHES THEN TIMER LIGHT FLASHES PICTURES SHOWS UP THEN GOES OFF WHILE TIMER IS FLASHING ON AND OFF ALSO
tv turns off after about 1 minute and then turns back on and continually does this
55" same issue not looking forward to shelling for a new bulb
replaced my bulb/entire assembly about 3 weeks ago. Now TV randomly turns off, standby light blinks for 20-30 sec, then TV comes back on.
Problem has happened 6 times over 6 hr period.
My tv kept shutting off after about an hour. I figured some kind of overheating since it continued after replacing the bulb. There was, in the fan discharge area, a small wire which I thought could be a temperature sensing wire. I moved it out of the compartment and now the tv runs for several hours before it shuts down. Is there some type of temperature sensing device that could be failing?
