posted by JuHu on Dec 30, 2007
The manual of my new Bosch Nexxt tells me to run a spin cycle with a small load. This is supposed to help with leveling, and it seems to be hinting at a spin only cycle. I can't figure out how to make it spin only. The manual hints at a spin only when it talks about the Refresh option.
Thanks for any hints!
Comment by JuHu, posted on Dec 30, 2007
Solution #1
If I could find a "spin" only function I would press it. There is no spin button or selection that is obvious.
Solution #2
Yes of course the shipping bolts are removed. I'm not saying it won't spin I'm asking for the magic buttons to make it do a spin cylce with no water added. The manual hints at this but no telling how.
Solution #2
2 Other Users Have The Same Problem
Comment by Guest, posted on Apr 13, 2008
same problem, after the cycle is complete, comforter is still wet but no spin only option....
Comment by Guest, posted on Jan 27, 2008
The only way to get it to spin, is to totally run a whole new washing program. And this machine is supposed to be energy efficient? Even after running the load thru another whole cycle; no spin at all. You could count the rpm's, at about 60 to 120 a minute. I could spin the clothes faster by hand. Bring back the "scrub board"!!
Best Solution
Unfamiliar with your machine; why not try by putting your machine on, inserting the small load (there shd be a small load button), then pressing the "spin" only function - & then "start".
Washing machines are much more complex than driving cars, the manuals dont print that. They are close to outer space modules....
Rating Locked! (?) JuHu has rated this solution as Thanks for Trying
Suggest a new solution for this problem
Post a New problem for Bosch 3.81 cu ft Nexxt 500 Plus
Email this problem
Email this problem
Can you Help with these Washing Machines problems?
Bosch 3.81 cu ft Nexxt 500 Plus Series Washer...
Acoustic signal
Acoustic signal
How can I deactivate the... Answer This...
water not entirerly draining,...
i have cleaned and checked... Answer This...
bosch washer spin only
How do we do this? there... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
Find Parts
