my panasonic lumix dmc-fx3 camera does not turn on. it was working fine one day and then the next it just stopped turning on. Screen is black, lense doesn't come out. I thought it was that i'd ran out of battery but i'd charged it not long ago, anyway i charged the battery up again and it still won't turn on. Any idea what it could be? Thank you
Your problem may be due to corrosion on the battery contacts inside the camera
which can prevent the full power of the batteries from flowing into the
camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with
a dry cloth (heavy corrosion may require cleaning with a wire brush,
steel wool, or sandpaper). Remove any residue that may have fallen
into the battery compartment during cleaning, then wipe both ends of
the batteries and place them back in the camera. This cleaning clears
the problem about 90% of the time. If it doesn't work for you, your camera may have
a problem that requires professional repair.
Panasonic Lumix DMC-FX 3 I dropped the camera and it still takes pictures but nothing shows up on...
(More)
Panasonic Lumix DMC-FX 3 I dropped the camera and it still takes pictures but nothing shows up on the screen--it's just abroken black line. How can i get this repaired?
panasonic DMC-FX3 turn lens come out but message please turn camera off and then on again. If you...
(More)
panasonic DMC-FX3 turn lens come out but message please turn camera off and then on again. If you turn it off lens stayes out until you turn it on again then goes back in and out
