Question about Sony Handycam CCD-TRV308 Camcorder
Sony camcorder my camcorder has a error message c:31: 23. it also has a blinking yellow arrow
    President:
  • 4,402 Answers
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Posted on Jan 16, 2008
Sony Handycam DCR-SR200 e:91:01 means?
From page 32 of the user manual that is available for download here: (click here)
The error message that you are seeing requires that you to take the camera in for service, since a failure has occurred that the owner cannot fix themselves:
E:20:ss / E:31:ss / E:61:ss / E:62:ss / E:91:ss / E:94:ss
A malfunction that you cannot service has occurred. Contact your Sony dealer or local authorized Sony service facility. Inform them of the 5-digit code, which starts from E
Nov 26, 2011 | Sony Handycam DCR-SR200 Camcorder
Video Camcorder Error Message
Per SONY; To service the C:31 code, Sony recommends you do the following: Turn off the camcorder. Remove the battery or disconnect the AC power adapter for 60 seconds. Insert the battery or reconnect the AC adapter. Turn on the camcorder. If the error message appears, service may be required.
Sep 15, 2007 | Sony Handycam CCD-TRV608 Camcorder
Sony 700X digital handycam
solution 1: Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times. solution 2: Turn off the camcorder. Remove the battery or disconnect the AC power adapter for 60 seconds. Insert the battery or reconnect the AC adapter. Turn on the camcorder. If the error message appears, service may be required. If your camcorder still shows the same error code, then you'll have to send in your camcorder for service additional info that might help: According to the manual, the error code C:31:xx:xx means an error that >the owner can fix by himself has occured and that by taking out the >cassette and replacing it or by disconnecting the battery pack and >fixing it back should solve the problem. Error "23" means: "S reel emergency during normal rotation", i.e. the problem is with the tape deck mechanism and specifically the supply reel.
Aug 21, 2007 | Sony Handycam DCR-TRV350 Digital Camcorder
Sony DCR-TRV17 - In the middle of filming, a flashing yellow square with a yellow light bulb inside the square appears wiht chimes. upper right hand corner is flashing C:21:00. I turned off recorder and...
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
May 31, 2010 | Sony Handycam DCR-TRV17 Mini DV Digital...
Screen has error message and won't play tape. What is wrong?
This message appears when the loading tape path become misaligned (mechanically unstable). Your camera just need mechanical adjustment from any expert and it will work fine again. Contact any service man for this.
Thanks for using fixya.
Jul 10, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
Blinking arrow and numbers, won't eject, play, rewind, fastforward
your camcorder must be broken. a specialist should work on that. go to your nearest technician to help you with. they have a tools for that. hope that helps!
CHARCOIS
Aug 08, 2008 | Sony Handycam DCR-TRV19 Mini DV Digital...
Error message
hi i have the sony DCR-PC53E camcorder with the error code E:61:10 does anyone have any suggestions on how to fix this problem any help will be more than appreciated
Apr 17, 2008 | Sony Video Cameras
Error code
Me too, but i guess no one has a solution
Jan 04, 2007 | Sony Handycam DCR-TRV27 Mini DV Digital...
Sony Handycam CCD-TRV308 Camcorder Logo
147 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
