Question about LG CU500 Cellular Phone
Sim cards will not work - LG CU500 Cellular Phone
  • 2 more comments
  • Anonymous Apr 22, 2008
    help with n95 china only one sim working
  • SandeepSaini Apr 29, 2008
    I HAVE LG U310
    THE PROBLEM IS THAT LOCAL SIM CARD DO NO WORK IN IT.
    IT DOES NOT ACCEPT ANY INDIAN SIM CARD.
  • habyb May 09, 2008
    please give me the country code & IMEI no. 010851-00-752681-1
    i will be very greatfull to you
  • Anonymous May 28, 2008
    i will be locked my sim card
  • 3 Answers
Reformat the card to FAT instead of FAT 32.
Posted on Jan 05, 2008
I have a sim card and using LG cu500 the problem is i 4got the simcard PUC Code can any1 help to reset the code.
Posted on Sep 24, 2008
MY MOTOROLA RAZR V3C SAID
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Aug 16, 2012 | Motorola Mobility RAZR V3
I put my old sim card in my new phone then I got my old phone back working and put the new sim card into my a107 phone and it read sim crash
Try to reinstall you sim card.
If this does not work, install you sim card back into the new phone.
If the sim card works in your new phone.
The sim card is not defective.
Your a107 may not be working correctly.
Jan 18, 2011 | Cell Phones
Sim card error
If your phone gives you the sim card error, it means either the sim is not properly inserted, or the phone cannot read the sim card. Remove the sim and reinsert it back in the phone to see if it will work.
Try to use the sim in another phone, if it works, then it means your phone has been restricted to some certain sim cards and if it does not work on another phone, then it means the sim card is bad and the solution is for you to get a sim swap.
If the sim works on another phone, then you have to flash the phone with the appropriate software and cable in order for it to be able to work with any sim card.
Take care and good luck
Dec 02, 2010 | Cell Phones
When I switch On my phone it says "Sim card not valid". And its not taking the Sim Card. But without the sim card its perfect. My IMEI is 359849016183862. Please help me...
Hi, what might be the possible cause of the problem is either the Sim card your using on the phone or the Sim tray where the Sim card is inserted in the phone.
You can use the Sim card in another phone to be sure the Sim card is working properly.
After that, if the Sim card works,That means that Sim tray is damaged and will need to be replaced.
Have a nice day.
Sep 14, 2010 | Cell Phones
What do you do when a tmobile tap cell phone says sim card not inserted and there is one inserted but its not working
Hi,when a phone says insert Sim when there is Sim card, Means that either the Sim card is bad or the Sim tray where you insert Sim is bad.
First use the Sim card on another phone and see if it will work, if the Sim card works, that means the Sim card tray will need to be replaced.
Take care.
Aug 12, 2010 | Cell Phones
Nokia 6500 slide sim card registration problemit normally says sim card registration failed immediately i on it
Hello
There are two things causing this problem,either your phone is not registered to the Sim card's network or your Sim card is corrupt
To find out where the problem has come from,you should try another Sim with your phone, if the Sim does not work then the phone is registered to a particular network and no other Sim card will work on it.
If you try another Sim card and it works then your Sim card is corrupt and you should replace it.but to be double sure,test the Sim card on another phone to see if it works,if it does then your phone is not compatible with the Sim card's network but if it does not work then your Sim has to be changed
thank you for visiting fixya
Jul 24, 2010 | Nokia N70 Cellular Phone
Won't accept ATT SIM card
Here is two possibility either you used sim in wrong slot like you have nano sim and you used into micro sim slot or other different slot. or your mobile is sim locked and that is why it not accepting at&t sim. here is how to unlock at&t simcard.
As your att sim working fine with blackberry so sim is fine no issue with sim card. on which mobile you have tried this sim as you have not mentioned your other mobile it is same as blackberry or apple or samsung mobile.
Sep 14, 2017 | AT&T Cell Phones
Sim card
Sounds like phone is locked or firmware is bad
Mar 15, 2009 | Motorola Mobility RAZR V3
Problem no sim card inserted
try to clean the contacts of your sim-card and also on your phone
if not see if your sim-card bends a little try to flatten it. ok...
peace!
Dec 01, 2007 | Nokia 8801 Cellular Phone
LG CU500 Cellular Phone Logo
118 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
