Question about Toshiba Satellite M115-S1061 Notebook
I was replacing a broken screen
Wanted to make sure it still powered up before putting all back together & no power at all battery or plugs.
    Master:
  • 619 Answers
Good Idea unplug the power cord take out battery ,place the lcd on table anti static matting.the assemble the PC.
Posted on Dec 30, 2007
My kindle is frozen at pause screen
had this the other day with a kindel. check the charger is working or change to another usb and leave on for 10min, then press the power button. if this does not work you will need to prise off the screen cover and undo the 10 torx screws and use a something like a kitchen knife not sharp and prise the top of gently as there is 4 clips holding down the board and screen, when its out remove the battery its a push the pins in on the sides and pull away. leave it unplugged for a few seconds then plug back in, now while its out plug the charger in, it will have an amber led show at the charging port area you will see it blink about a minute after charger is plugged in, now press the power button and it should turn on now (button is in the same place as the case ) leave it on charge out of casing and when charged and the led is green replace in case remove power lead and put the power connection on the board in first to the case and push down on the corners you will hear it click, then screw the case back down. (remember when the screen cover is off put it to one side and make sure nothing gets onto the sticky side) when all back together with the screws put the screen cover back on. and you are done.
Aug 12, 2017 | Tablets & eReaders
Wont start when I push button.
Make sure when you put it back together that you did not forget to plug in the power button or button cable. Also the battery may not be charged if it is new. Batteries do not hold charge being li-ion for a long period of time.
Apr 15, 2014 | HP Mini Computers & Internet
Acl lifestyle lp522The power supply went off in my house and now the programme panel has no power to it even though the mains is now live. Is it broken?
Try removing it from the base and remove the batterys to kill all its power. Be sure the batterys are OK with good contact. Wait a minute and put it back together. If the factory program doesn't display, its probably bad.
Dec 18, 2013 | Heating & Cooling
Was using my Hp Pavilion dv7 laptop, suddenly turned off while the charger was plugged in. Turned back on then shut off again. Now my laptop wont even turn on, and there are no lights that even come on,...
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Sep 26, 2010 | HP Pavilion dv7-1245dx Notebook
Samsung r60 plus does not recognise a/c power,i put in the battery which does not charge and it works
Sep 14, 2010 | Samsung Computers & Internet
I have an acer aspire 7720g and recently it has been changing from battery to charged by itself, i know this because the battery icon appears in the tool bar. When it does this the power button goes to...
Sep 14, 2010 | Acer Aspire 7720 Notebook
The ac power plug was broken loose on my sony vaio vgn fw140e and finally the laptop failed to power up. I'm pretty sure the power adapter came loose from the mother board . I just don't know how to fix...
Sep 09, 2010 | Sony VAIO VGN-FW140E/W Laptop
How can i get rid of a bios password
This hasworked for me with Acer and Toshiba. Find your Cmos battery (RTC Battery) disconnect it, now get another cmos battery plug like the one connected to the battery on the system and cut the battery free and twist the wire ends together. You are going to use this to short the points on the battery socket. You can get a plug off of a dead laptop motherboard. Go to a computer shop and ask them for one, I'm sure they have them laying around. Now power up the laptop and let the bios load. At this point shut the laptop back down and replace the short plug with the battery and put it back together. Fire up the laptop and all should be well. On some systems you have to take the laptop apart in order to get to the rtc battery...same procedure except you won't be able to see the system go to the BIOS, not a big deal, just count to 30 with power on and then shut down, put laptop back together and power back up once it is back in one piece. good luck
Sep 20, 2009 | Toshiba Satellite M115-S3094 Notebook
Acer 5100 laptop doesn't work on ac or charger battery
Motherboard is bad and will have to be replaced unless of course the AC Jack on the back of the laptop is loose. That would cause the ac adapter not to charge and then you would have to take the motherboard out and put solder on each leg on the bottom of the ac jack to make sure it stays in place then the ac adapter can charge the battery properly.
Even going thru the solder method the motherboard could still be bad and have nothing to do with the ac jack.
Mar 08, 2009 | Acer Aspire 5100 Notebook
Toshiba Satellite M115-S1061 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
