Question about Consew 206RB
Thread breaking Hello.  I have a Singer 9410 machine.  Recently as I am trying to sew, the thread keeps breaking after just a few stitches.  The thread frays and then breaks.  What is the problem? Thanks!
SOURCE: thread keeps breaking
347 singer Bobine setting
Posted on Dec 30, 2007
  • 20 Answers
SOURCE: Blind hemmer
First get a new quality needle of the right size for your machine use a good quality hemming thread and check your tensions. If this fails to fix the problem you will probably have to have the timing checked.
Posted on Jun 07, 2008
  • 34 Answers
SOURCE: thread breaking on Simplicity Denim Star
Hi, when your thread breaks or frays right before in goes through the eye of the needle:
  1. Change your needle - after awhile, the eye can wear down and cause your thread to break or fray, eventhough it looks like the thread isn't even going through the needle. When you change your needle, make sure to install a needle that is compatible with the thread you are using (see below).
  2. If your thread still frays or breaks, make sure you've threaded your machine correctly. Most machines have a hook or bar right above the needle that your thread need to pass thru before you put the thread thru the eye of your needle. Sometimes that spot above the needle is really hard to get to, and sometimes the thread slips out. Always a good idea to double check. If you are still having problems, the needle you are using is probably the wrong size.
There are lots of needles on the market, and lots of threads. You need to make sure your needle is compatible with the thread you use for each project.
The most common needles are size 80 and 90 universal needles, which are fine for most sewing projects. But if you are using a specialty thread, you need to use a needle that is designed to work with that particular thread. For example, top stitching needles have a larger eye than a universal needle, because top stitching thread is thicker than sewing thread. The same is true for metallic thread - needles made for metallic thread an eye designed to allow the thread to pass thru without fraying. Further, if you using fine thread, you need a small needle.
FYI - unfortunately, thread sizes do not correspond directly with needle sizes. Small needle numbers indicate a needle with a small eye. But the smaller the thread size, the larger the thread. For example, size 50 thread is very fine and would usually be used with a size 70 needle. Size 30 thread is fairly thick and would probably be used with a size 90 top stitch needle.
Hope this helps, and remember, you should always change your needle after about 10 hours of sewing, no matter what size needle you are using. If you have more questions, please post again. Thanks, Ginny
Posted on Jan 31, 2009
  • 374 Answers
SOURCE: need sewing machince help????
breaking thread and thread below not hook up by upper thrread, this is due on not properly set up of thread tension,first check bobbins windin35caecd.jpgg see figure.the threads should
be counter clockwise.
the theading on upper set up should prorerly inserted follow figures.7dabcae.jpg
the dial set up tension should start at #3 to # 5
the stitch tension should be set to # 8 to # 12
use trial run for fabrics,diffferent set up in every fabric tru to study before sewing in other fabrics.have a nice day don't forget to rate me.thank s a lot
Posted on May 17, 2009
  • 1952 Answers
SOURCE: Thread frays and breaks when sewing and embroidering.
Make sure that the machine is threaded correctly, that the needle is in properly, that the bobbin case and bobbin are both inserted correctly and that you are not using old thread.
Make sure that there is a new needle in the machine and loosen the top tension about a number
You need to carefully re-thread the machine.
Posted on Aug 03, 2009
  • 53 Answers
SOURCE: top thread keeps breaking
This sounds like a backwards needle. Take out the needle and when you re-insert it back in, make sure that put the flat side to the back.
Posted on Jun 07, 2010
0 characters
1 Points
The upper thread tension keeps breaking the thread, no matter how low I set the tension. How do I fix it?
Not a technician, but I had same issue not long ago, it was old dried out thread. Once I replaced with new thread, no more issues. Something easy to try. Also might want to double check to make sure no thread is between the pressure plates. I use canned air to spray them out once in a while between annual cleaning.
Apr 21, 2016 | Singer 8770 Curvy 225-stitch Computerized...
I have a Quantum CXL Singer sewing machine and the thread keeps breaking. It will make about 3 stitches and breaks. It is breaking in the same place.
Make sure the thread coming off the spool is not wrapping around the spool spindle. Install a brand new needle. Remove ALL the thread from the machine. Clean bobbin area of any dust, lint, threads. Set upper tension to the midpoint. RAISE the presser foot and then totally re-thread the machine from beginning to end verifying the sequence is correct. Test.
Why Does My Sewing Machine Top Thread Keep Breaking Howcast
Oct 06, 2015 | Singer Sewing Machines
Singer featherweight 11 cotton keeps breaking
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Jan 28, 2013 | Singer Featherweight II 117
I recently rec'd Singer Curvy 8770 as gift. Trying to use for first time and thread on underside of stitches is loose. Have tension on top dial as far as 9. I hve been sewing for forty+ yrs.
Try this, totally rethread with the presser foot up, then pull the top thread, it should move smoothly, then lower the presser foot, now pull the thread, it should barely move. This seats the thread in the tension discs.
Apr 11, 2011 | Singer Curvy 8770 Electronic Sewing...
Skipping stitches and upper thread breaking on JCPenney 6600
Here are a few things to try.
* Raise your feed dogs if your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you're sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). And make sure your needle is appropriate for the type of thread you're using.
* Adjust the pressure of your pressure foot, it may be too light for your fabric.
* If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
* Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: If you change your needle plate, check to make sure your needle aligns perfectly with this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope this helps.
Mar 14, 2010 | Singer 5062 Mechanical Sewing Machine
Top thread on machine keeps breaking , sews for a while, jumps a few stitches then breaks. Seems to make one long stitch every so often.Thanks
Refer to the manual for threading and thread the machine with the presser foot up.
Make sure the bobbin is inserted so the bobbin thread is feeding in the correct direction from the bobbin spool and through the proper guides.
Mar 08, 2010 | Singer 3116 Simple
My sewing machine keeps getting jammed when sewing. the top stitch keeps getting tangled in with the bobbin thread and jamming up the machine.
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
I hope this helps.
Sep 11, 2009 | Singer 5160 Mechanical Sewing Machine
Singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Mar 15, 2009 | Singer 3116 Simple
Embroidery thread breaks after about three stitches
I had the same problem....I tried cleaning it just like you did. Eventually, I changed the needle and it took care of the problem :)
Hope that helps!
Nov 30, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Sewing machine either breaks thread or comes unthreaded every time i try to sew.
Your threading is not right, totally remove your thread and rethread according to the manual directions and dvd. If, you still have problems call Singer at 1-800-4singer
Sep 29, 2008 | Singer 3116 Simple
Consew 206RB Logo
Top Consew Sewing Machines Experts
River bottom
Custom Exchange
Custom Exchange
tina gallow
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
