Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Problem for Sony Grand WEGA KDF-55WF655. Hello,
Problem for Sony Grand WEGA KDF-55WF655. Hello, My TV was working fine when I shut it off but it will not turn back on. I now have the standby light flashing 5 times. When I power it back on the fans come on and the standyby light flashes green for about 30 seconds then it will start flashing red before the TV shuts down again. All the time there is no picture or sound. Any ideas?
  • 10,594 Answers
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Posted on Oct 21, 2009
I own a sony gand wega projection tv model number kdf-55wf655 and the hue does not work at all. I see only green people!!!!
Posted on Dec 12, 2009
Same thing happened to me yesterday (5 times Red LED) so I took lamp out, then put it back because company was coming. Then set powered on OK and is working now, with nno new parts. Just lucky for awhile, I guess.
Posted on Nov 05, 2009
SOURCE:
For a KDF-55WF655 SONY PROJECTOR TV, WHAT REPLACEMENT LAMP DO I NEED
Required lamp for Sony KDF-55WF655tv is as follows:
A1085447A .... LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200
Thanks.
Nov 02, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony grand wega
It may be a power supply fault
May 19, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF-55WF655 picture and sound are going on and off. The green light flashes when they are off and when they come back on the picture comes on first then the sound.
These are symptoms of weak lamp as lamp in tv is reaching to end of its working life and will be replaced to fix this issue.
Lamp replacement procedure would be written in user manual and its easy.
Please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Apr 18, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV repeatedly goes into standby mode and then comes back on
Resolder Horizontal section & SMPS Power Supply with Soldering Iron
Jan 02, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Picture and sound shut off, blinking green standby
MY SONY PROJECTION TV WENT BLANK WITH NO SOUND GREEN LIGHT WAS ON WHATS WRONG
Oct 14, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have a grand wega kdf-55wf655 projection tv.
The detail of your fault is given below according to the SELF DIAGNOSTIC SYSTEM.
The description is given below:
6 : Low B error When no "DD 6V " is detected, pin 129 of TV-micro is low and it turns off the main power.
Suggestion:
This problem is little bit technically difficult, therefore i advise you to please contact any expert who can handle this or contact SONY SERVICE CENTER.
Hope you will understand my saying.
Thanks for using fixya.
Jul 02, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Suggestion:
Changing the lamp in a Sony Wega KDF46E2000
Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
Click Sony Support to download instruction manual of KDF-55WF655
that has detailed procedure of lamp replacement.
lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
May 02, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
1,850 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
