2004 Nissan Quest Logo
Posted on Oct 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2004 nissan quest DTC P0507. Can't get IAVL to
2004 nissan quest DTC P0507. Can't get IAVL to execute properly to correct high idle. Followed field procedure w/o use of CONSULT II Tool. Problem occured after replacing spark plugs at 97K mi. Had to disconnect and R&R TB to R&R plugs. NO vacuum leaks have been detected.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 20, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2515
Points
My quest 2004 idle below 500, start up then off, have to start couple times when the engine is cold. when i pushed the gas pedal, it smells gas.
LOS COMPUTER REPAIR
Level 2:
  • Expert 27 Answers
  • Posted on Feb 25, 2010
LOS COMPUTER REPAIR
Expert
Level 2:
Answers
27
Questions
0
Helped
29408
Points
102
Have the car re-learn the larger amount
of air volume that the modification creates, here is the procedure for doing this. It's
similar to the ECU clearing procedure:
1) Drive the car to "warm up" temperature. Make sure your idle is close to 700 rpm.
2) Ensure any battery draining devices are off. Ie. headlights, interior dome lights, HVAC,
stereo.
3) Turn the car ignition key to "OFF"
4) Wait ten seconds
5) Turn the key to "ON" (not start)
6) Wait three seconds.
7) Perform the following five times in five seconds or less. Fully press the gas pedal and
release.
8) Wait seven seconds from last of the five releases.
9) Fully press the gas pedal and hold down. Within ten seconds the "Service Engine Soon"
light should begin to blink.
10) Wait another ten seconds (while still holding the gas pedal) and the "Service Engine
Soon" light should stop blinking.
11) As soon as it stops blinking, release the pedal, start the car and check the idle
(should still be around 700 rpm)
12) Let the car idle at 700 rpm or so for about 25 seconds, rev the engine a few times and
then let it return to idle.
13) Shut the car down.
You car has now relearned the new air volume, which should be different than it was
(stock). You may notice a bit of a rough idle for the next 20 miles. This is normal and
will go away. The reason you should make sure idle is around 700 rpm (full warm up) is
because the car measures the air curve in relation to idle, so you don't want to confuse
it.
  • Anonymous Jun 04, 2011
    What if your idle is 2000 to 1500 rpm, will this procedure work? I can't get idle down enough to reach 700 rpm.
3answers
How to fix a dtc p0507?
A vacuum leak Leaking air intake after the throttle body EGR valve leaking vacuum A faulty positive crankcase ventilation (PCV) valve Damaged/failed/dirty throttle body Failed EVAP system Failed IAC (idle air controller) or faulty IAC circuit
1helpful
Correct code P0504?
What Colorado do you have ? 2 wheel or 4 wheel drive ? Sport ,sport LS 3.5L , Z71, Z71 LS. etc. what size engine ? an does it have electronic throttle control ? I have factory service info an it is not showing that code .
DTC P0506
Circuit Description
The throttle actuator control (TAC) motor is controlled by the powertrain control module (PCM). The DC motor located in the throttle body drives the throttle plate. In order to decrease idle speed, the PCM commands the throttle closed reducing air flow into the engine and the idle speed decreases. In order to increase idle speed, the PCM commands the throttle plate open allowing more air to pass the throttle plate. If the actual idle RPM does not match the desired idle RPM within a calibrated time, this DTC sets.
DTC Descriptor
This diagnostic procedure supports the following DTC:
DTC P0506 Idle Speed Low
DTC P0507
Circuit Description
DTC Descriptor
DTC P0507 Idle Speed High
Cleaning the throttle body mite take care of it !
Cleaning Cleaning An Electronic Throttle Body Safely
2answers
Hy is there a code p0507? and how do i fix?
This P0507 code is one that's sometimes triggered on vehicles that have electronic throttle control. That is, they don't have a regular throttle cable from the accelerator pedal to the engine. They rely on sensors and electronics to control the throttle. In this case, the P0507 DTC (diagnostic trouble code) is triggered when the PCM (powertrain control module) detects an engine idle speed that is greater than the desired (pre-programmed) RPM. In the case of GM vehicles (and possibly others) if the idle speed is over 200 rpm higher than expected, this code will be set. A P0507 DTC trouble code may be caused by one or more of the following: A vacuum leak Leaking air intake after the throttle body EGR valve leaking vacuum A faulty positive crankcase ventilation (PCV) valve Damaged/failed/dirty throttle body Failed EVAP system Failed IAC (idle air controller) or faulty IAC circuit. This DTC is more of an informational code, so if there are any other codes set, diagnose them first. If there are no other codes, inspect the intake air system for air or vacuum leaks and damage. If there are no symptoms other than the DTC itself, just clear the code and see whether it returns. If you have an advanced scan tool that can interact with the car, command the idle higher and lower to see if the engine responds appropriately. Also check the PCV valve to see if it's blocked and needs to be replaced. Check the IAC (idle air controller) if equipped, verify it's operation. If available, try swapping in a new throttle body to see if that fixes the problem. On Nissan Altimas and possibly other vehicles the problem may be fixed by having the dealer perform an idle air relearn procedure, or other relearn procedure
Nissan p0507
EGR valve
leaking vacuum
you would need to check these. some times its just a glitch in a sensor when the revs go to high. remove the code and see if it comes back. can activate this code if revs to high.
2helpful
I have the po507 code on my nissan quest .. it is this
this obd2 trouble code table can help you understand the meaning of code.
for p0507, you can try this:
If you have an advanced scan tool that can interact with the car, command the idle higher and lower to see if the engine responds appropriately. Also check the PCV valve to see if it's blocked and needs to be replaced. Check the IAC (idle air controller) if equipped, verify it's operation. If available, try swapping in a new throttle body to see if that fixes the problem. On Nissan Altimas and possibly other vehicles the problem may be fixed by having the dealer perform an idle air relearn procedure, or other relearn procedures.
4helpful
I have a 2005 Nissan quest and I'm getting a p0507
No..you can't adjust the idle...
Possible cause---Electric throttle control actuator, intake air leak or PVC system...check these 3 things...
8helpful
3answers
My 2005 altima idles high and engine code
41helpful
4answers
2002 nissan altima p0507 idle problem
I had the same problem before. after using the scanner i got a code number P0507. "Idle Air Control", New 2002 and up Nissan models like my Altima don't have an idle valve or sensor like older models to be replace. Here's the solution " Replace your "Throttle Chamber" the idle sensor is build in it, there is no other way to fix this problem. the throttle chamber is about $175.00 at your Nissan Dealer. The need your core or you will need to pay extra money. No need for expensive mechanic shop, you could do this your self. the throttle chamber is so easy to remove, four screws holds it together. I will take you about ten to twenty minutes to replace it. Please trust me and you will save big bucks!!!!!
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Nissan Expert? Answer questions, earn points and help others
