Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Lens retract problem
When i press the power button the lens comes out a tiny bit and stops dead... press the power button again and the lens goes back in. i thought the motor in there was done but when i press the review images button the lens comes all the way out and back in again! so it seems as if the motor is fine. any help would be much appreciated!!!
  • 1 more comment
  • Anonymous Sep 19, 2008
    i am also having same problem. gives 'lens error restart'
  • gennery Sep 20, 2008
    That happnens with mine " lens error restart camra"
  • Anonymous Sep 29, 2008
    the lens stuck inside the body when push the power-on button, And on LCD "Lens error, restart camera" message persistently displays!!
  • 489 Answers
Hi
What you are seeing is the Canon generic stuck lens error message.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera, sorry.
Good luck from...
Darntoothysam com
Posted on Sep 22, 2008
  • Canon Master
  • 4,738 Answers
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 31, 2007
Lens on my S7000 doesn't retract when switched off - now permanently extended - and camera dead
This is going to require service / repair at the shop, not something you will be able to correct.
Jan 26, 2013 | Fuji FinePix S7000 Digital Camera
It turns on but beeps 3 times then shuts off
Hello and Welcome to FixYa!
This indicates that the Camera lens is retracted, to D.I.Y be careful not to be aggressive with the Gadget If the lens is retracted, hold up the camera to your eye and look at the lens. If you see one end sticking out a little bit, push that side in and press the power button. It should work. If the lens isn't retracted, push the lens around until it is in its regular position. When you press the power button, it will retract and come out again and should work fine.
If the procedure above does not resolve the problem, your camera requires service, fill out our online service request form so that we can further diagnose and correct the problem.
I hope this will help you out, If you are still having issues/questions, do ask.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
Aug 13, 2010 | Samsung L100 Digital Camera
On last pwr down the lens only retracted halfway. Now, press pwr button and the pwr lite blinks 3X, stays lit, blinks 3X, goes out and the camera does nothing. Is it brain dead? Tnx, Bobert
Try replacing or charging your batteries, then see if that fixes it. Lens could be stuck by dirt or something, see if you can gently assist it closing when you power it on again. Other possibility that comes to mind, other than being "brain dead", is that the gears that drive the lens have broken or jammed. Not sure what a camera shop would charge to check it out, but you might try to get a good used one on Ebay, they seem to go for around $60. Hope this helps!
Feb 25, 2010 | Olympus FE-340 Digital Camera
Lens goes in and out, stays out when off and says
I'm sorry that the lens of the camera is not retracting. Please make sure that the battery is fully charged and there are no dust particles near the lens which stops retracting. Check if you are able to access the Menu. If yes, then, please Initialize the camera under Main settings 1 Menu. If you are not able to access the menu, you may have to power reset the camera by removing the battery and press n hold the power button for 1 minute continuously. After that leave the button and insert the battery and check if it helps. If the issue still persists, your camera will require service.
Sep 26, 2009 | Sony Cameras
Samsung L100 digital camera beep problem
Hope this advice helps!
Aug 04, 2009 | Samsung L100 Digital Camera
Problem with lens
throw it on the floor again
IT WORKS!!!!! YYYYEEEEEEEEEEAAAAAAAAAAA
Jul 10, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Nikon Coolpix 4100
How wbout changing your batteries. mine does this if my batteries are dead.
Hope this helps
Jun 08, 2008 | Nikon Coolpix 4100 Digital Camera
Lens wont retract
Lens motor is shot - check out Olympus web site for repair options-not cheap
Jul 04, 2007 | Olympus FE-140 Digital Camera
Lens wont retract, Camera unresponsive
I like Google. In an attempt to find a solution for this same problem, I stumbled upon this site. Seeing as this was posted months ago, I'm not sure if this will be checked again, but it can't hurt to have a suggestion, just in case it turns out to be right. Without opening the camera for sure, what I can tell is that the lens extends and retracts by rotating. Essentially, the lens is a series of threaded cylinders that, when turned one way, move outwards, and when turned the other way, move inwards. What you're describing, especially the bit about the clicking, sounds like this threaded bit of the lens casing has come either off-track, or snapped, or something to that effect. I would suggest (if you're feeling secure in your abilities) taking the device apart and getting a good idea of exactly how the lens retracts and extends. Once you've determined this, you may simply be able to reason what would stop it from moving. I can almost guarantee that if the lens is designed to extend upon power-up and retract upon power-down, then an attempted power-up would be aborted if the lens can not extend. I might be losing the focus a tiny bit, but the idea is that essentially the lens will not screw in or out because it's either jammed, or cracked, or just off its track somehow. This can easily happen if the camera is dropped or jostled just hard enough. So my solution, if you can consider it that, is to disassemble the camera to see whether the threads are just off-track, or if there's some sort of mechanical breakage inside. If it's the former, then it may be as simple as realigning the threads. If it's the latter, the cheapest solution would be to find another of the same camera on eBay that is broken in a different fashion, then use the part(s) that you need to get yours working again. I hope this helps someone!
Nov 22, 2006 | Casio Exilim EX-Z57 Digital Camera
Power problem with 450
The LCD goes dark after the camera has been inactive for a time, to save battery. When that happens, you can easily restore the LCD display by half-pressing the shutter. If you want to, you can turn this off by selecting menu-setup-SleepTimeout and turn it off. (I don't recommend it, though, as the LCD always on will drain your battery).
Sep 08, 2005 | Pentax Optio 450 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
747 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
