Question about Canon Pixma iP6000D InkJet Photo Printer
Driver Installation Had to do a system restore and now when running the printer setup disc it is hanging up at the point where I am to connect the printer and turn it on. I've had this problem before and I need to take better notes. I have to change a default printer somewhere, but can't remember where.
    President:
  • 4,402 Answers
Solution: Uninstall / reinstall the printer driver (Windows) PIXMA Printers
Uninstall and Reinstall the Printer Driver (Windows) Follow the steps below to uninstall the printer driver:
  1. Select 'Programs' or 'All Programs' from the Start menu.
  2. Select the Canon printer driver you want to uninstall, and then select 'Uninstall' from the menu that appears.
    Note: Click here if your printer does not appear in the Windows 2000, Windows XP or Windows Vista Programs menu.
  3. When the confirmation message shown below is displayed, click 'OK'.
  4. A window showing the progress of the uninstallation is displayed. Wait until the "Uninstall successfully completed" message is displayed, and then click 'OK'.
    Note: If you use Add or Remove Programs to uninstall the printer driver, the printer model name will remain in the Start menu. To completely remove all files, including the printer model name from the Start menu, uninstall the printer driver using the procedure described in step 2.
In Window XP or Windows 2000, use the steps below to uninstall the printer driver if your printer does not appear in the Programs menu.
  1. Make sure your printer is connected and turned OFF (or the power cord is unplugged).
  2. Turn on your computer and log on as Administrator.
  3. Open the Printers window.
    For Windows Vista
    Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    For Windows XP Home Edition
    Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
    Right-click the Canon printer icon for your model printer and click Delete.
  4. Click 'Yes' to proceed with the deleting process.
  5. Click 'OK' to acknowledge you have deleted your default printer.
  6. Click 'File' from the Printers window then click 'Server Properties'.
    Note: For Windows Vista, click your right mouse button on any empty space within the window, and then select 'Server Properties' from the menu that appears.
  7. Click the 'Drivers' tab. Select your Canon printer from the list and click 'Remove'.
  8. Click 'Yes' to proceed with the deleting process.
Follow the steps below to reinstall the printer driver:
  1. Turn off the printer.
  2. Connect the printer cable to the printer and the computer.
  3. Turn on the computer, and start Windows.
  4. Insert the Canon Software Setup and User's Guide CD-ROM into the CD-ROM drive. Setup Starts automatically.
    Note: If Setup does not start automatically, click 'Start' and then 'Run' from the taskbar. In the 'Open' box of Run window, type x:\msetup.exe (where x: is your CD-ROM drive letter). Then click 'OK'.
  5. When the Master Setup screen is displayed, click the 'Custom Install' button.
  6. Uncheck (click on the check marks) all items listed except for 'Printer Driver', and then click 'Next'.Driver Installation - ip1800_win_easy_inst2.jpgp://i.fixya.net/uploads/images/ip1800_win_easy_inst2.jpg" alt="ip1800_win_easy_inst2.jpg" class="h_mi" />
  7. When the License Agreement appears, click the 'Yes' button after reading the agreeDriver Installation - ip4000_install3.jpgk 'Next'.
  8. File copying begins. After all files are copied, the Printer Port dialog box is displayed. When the dialog box is displayed, turn on the printer.
    Note: If the port is not detected at this time, disconnect the cable frDriver Installation - printer_connection_install.jpgt.
    Click 'OK' to end the printer driver installation.
Note: If you previously used a Canon printer that was connected with a USB cable, a message reporting that the USB driver will be updated may be displayed. Click the OK button to update the USB driver and restart Windows.
Posted on Jan 15, 2008
Getting Not Responding
Get a reputable Computer technician to do a wipe and reload for you. Usually when a computer is slow or programs just hang, it will be very hard for end users to figure out the bottle neck, or anything that is causing that, and you will end up spending a lot of money trying to find the bottle neck. But before you find the computer tech, Try this method,,,,
Go to control panel and on the search column just type SYSTEM RESTORE and the select the Restore system files and settings from a restore point. While you are doing this make sure that your computer is connected to the charger. In the system restore, select a restore point that is earlier than when the problem started. This will take a few minutes depending on the machine, then all will be well. If the problem continues, then you should just find a Windows 7 Home Premium installation disc and repair your computer
Oct 06, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Hp photosmart 310c will not install on windows 7
IssueThe HP printer software installation fails to run in Windows 7 on a computer with an AMD C-50, C-60, or Z-01 1.00 GHz processor. After you insert the HP printer software installation CD or run the driver installation downloaded from the HP website, the setup does not open. You might receive an "HP Installer Setup has stopped working" error message.
'HP Installer Setup has stopped working' or Setup Does Not Run When Installing the HP Printer Software in Windows 7IssueThe HP printer software installation fails to run in Windows 7 on a computer with an AMD C-50, C-60, or Z-01 1.00 GHz processor. After you insert the HP printer software installation CD or run the driver installation downloaded from the HP website, the setup does not open. You might receive an "HP Installer Setup has stopped working" error message.note.pngNOTE:This document does not apply to HP LaserJet printers.Preliminary stepThe solution in this document resolves software installation issues only for Windows 7 computers with an AMD C-50, C-60, or Z-01 1.00 GHz processor.
  1. On the Windows taskbar, click the Windows icon (c01319360.gif ), right-click Computer , and then click Properties .
  2. In the System section under Processor , find the manufacturer, model, and speed (GHz) of the processor.
If your computer runs an AMD C-50, C-60, or Z-01 1.00 GHz processor, continue with the steps in the following solution.SolutionFollow these steps to download and install the newest, full-feature version of your HP printer software. Then, download and install a software patch to complete the installation.Step one: Download the softwarenote.pngNOTE:You must download the Full Feature software to resolve the installation issue.
Mar 24, 2013 | HP PhotoSmart Office Equipment & Supplies
How do connect a x6650
Simply run the X6650 installation software on your computer. The software will also show you detailed instructions on how to setup the printer itself. If you don't have the installation disc, you can download and install the X6650 printer driver from the Lexmark website.
Please visit the Lexmark website to download and install the Lexmark X6650 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
Jan 15, 2012 | Lexmark Office Equipment & Supplies
HOW TO INSTALL OUR PRINTER?
dear friend,
these are basic steps to install your printer.
1) you need a printer driver cd or driver setup file.
2) run your setup file and follow the steps
3) while your setup is running connect your printer with your computer and give them power.
4) after installation is complete restart your system.
5) done.
u r ready for give print
Apr 17, 2010 | HP DeskJet 3745 Printer
Canon mp 270 drivers wont install
http://software.canon-europe.com/products/0010753.asp
used this link and download your driver and follow these basic steps while installing printer.
5) done.
Apr 17, 2010 | Office Equipment & Supplies
Brother MFC-6800 scanner isn't recognized in XP
I think that's a defective scanner. Common issue, everything works but scanner not even detected as a device in xp. But printer detects fine. If you don't see any ghost or uninstalled drivers for the scanner i suspect hard ware failure. Probably some internal cabling or connection within the scanner itself.
Nov 08, 2009 | Brother MFC 6800 All-In-One Laser Printer
HP C6180 printer install hangs on my XP Thinkpad T43
If the installation hangs using the setup cd , the best thing that you can do here is to download the printer software from HP site and install it after that and that should correct the problem..
Sep 11, 2009 | HP Photosmart C6180 All-In-One InkJet...
USB installation problem
This problem comes somtime when you connect the printer prior to dirver installation.
  1. Rmove your printer driver from Start-> Printers and Faxes
  2. Right click on printer icon select Delete
  3. Re-boot system, before re-boot remove all USB connections.
  4. Start Installation from Setup CD
  5. Don't attach printer to system till Installation finished or Setup says to connect the printer.
Thanks
Iqbal
Apr 15, 2008 | Lexmark X2550 All-In-One Printer
System Recovery Problem
Phillynoy was right on! I have been fighting with the recovery and restoration hanging. When I read Phillynoy's comment about the optimal speed setting, I called Gateway. The tech said she would be glad to tell me how to change those settings for $59 tech fee (first 30 minutes). So I decided to look in the bios and there it was under Advanced. Change to disable the optimal speed and the computer has finally completed the installation! Praise God!
mamabearj2000
Jan 22, 2008 | Gateway 7320GZ Notebook
Windows Vista hangs while browsing
An operating system hanging indicates that either the program you are using, or the operating system itself, has crashed. The easiest way to eliminate hangs is to start up the computer from your Windows installation disc, and then either choose to Repair your installation, Restore the installation or install a new Windows OS.
Your computer came with a recovery option that lets you "reset" or recover to a known "good point". Hold down the "Alt" key and then hit the "F10" key (both at once) to activate the feature, and then follow the on-screen directions.
Nov 09, 2007 | Computers & Internet
Canon Pixma iP6000D InkJet Photo Printer Logo
125 people viewed this question
old marine
old marine
