Home | Samsung | Digimax S730 Digital Camera | How do i fix this pro...
Samsung Digimax S730 Digital Camera
Problem for Samsung Digimax S730 Digital Camera
How do i fix this problem my camera won't turn on
By naomi_1294 on Oct 21, 2009
how do i fix this problem my camera won't turn on when i press the power button it has an orange light and makes a really loud noise how can i fix this problem
Best Solution
posted on Nov 19, 2009
Very Helpful)
UnionMusic
Rank: Apprentice
Rating: 100%, 1 votes
IT WORKS!!!!! find a power supply for something else, around 5v, i used one from an fusic phone. batteries out, plug it in, power on, lens pops out, just a couple of seconds. then unplug, batteries back in and thats it. i just did this 30 sec ago. it works!!!!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Oct 21, 2009
Very Helpful)
BillB-SA
Rank: Guru  Samsung Cameras & Camcorders  Expert
Rating: 85%, 339 votes
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Was this helpful?
Yes
No
Popular Solutions for Samsung Digimax S730 Digital
Questions and Unsolved Problems for Samsung Digimax S730 Digital
Do you recommend Samsung Digimax S730 Digital Camera?
Answer
Answer
I would like to set my S73 camera back to factory settings
Answer
Batterys go dead when not in use-I can take one picture-turn it off--go back in a few hours and the... (More)
Answer
i can not start the camera. I have the "select usb computer/printer messege on the camera... (More)
Answer
The screen is white, even when I pull out the batteries and memory stick for a very long time. Still... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung Digimax S730 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
