Question about Linksys Wireless-N WRT150N Router
New network has been detected
Everytime i setup the router it shows it is working correctly. but then it say that it has found two or more connections and wants me to run setup. Why is this happeneing. there is no there network my desktop is connected to.
  • 84 Answers
Your neighbours may have wireless internet
Posted on Jan 03, 2008
    Scholar:
  • 112 Answers
You may have only 1 wireless device at your home BUT your wireless computer may be picking up another wireless signal that is near you and broadcasting. If this is the case make your wireless device the default connection. BPCS
Posted on Dec 30, 2007
I am trying to do the wifi protected setup with the 8 digit pin it gives me, I get the pin press the wifi ps button, it fails everytime. what are the correct steps to take please help. Alcatel One Touch...
What is giving you the 8 digit pin is it coming from the wireless router or wireless network provider ?
on your phone
To turn Wi-Fi on and connect to a wireless network
Drag down notification panel and touch
to access
Settings
Touch the switch
beside Wi-Fi to turn on/off Wi-Fi.
Touch
Wi-Fi
, the detailed information of detected Wi-Fi networks is displayed in the Wi-Fi
networks section.
Touch a Wi-Fi network to connect. If the network you selected is secured, you are required to enter
a password or other credentials (you may contact your network operator for details). When finished,
touch
Connect
Nov 02, 2014 | Computers & Internet
I have a new ipad and it is not picking up the wireless router even though it shows full strength.
When you select the connection on the Wireless Network Scanning. Turn it OFF and ON again.
If it shows on the network and is connected.
Just click on it and then on FORGET DEVICE.
Rescan... by ON and OFF again.
Try to put the correct password for router access.
It is probably an incorrect password for granting access to the wireless network.
If it shows on other computers and the network is up and working. You should have no problem.
If the Ipad is not detecting the router, then the problem is on how the network is set up.
You will then have to work with the router settings.
Hope it helps.
God Bless You!!
Remember to rate this solution!!
Feb 21, 2011 | Belkin F5D8236-4 Router
Lost wireless connection. Diagnosis said network connection o.k but cable not connected to network adapter for local area connections. cheked and all cables connected even changed blue line ethernet...
Check if the wireless works by directly connecting to the Lan port and the system. If it works, you may have to check for the Wireless Home Setup. Check if there are changes made to the Freequencies. 802.3 g usually gives max range. In case you are working at a distance which the signal wouldnt cover, the system can show network not detected. Also try to work on a Manual Address mode than DHCP and find if the network is getting detected. Check if the WNC is enabled and if working on DHCP, try do a tcp ip reset using the command from the command prompt... by using the command ipconfig /release.
and then ipconfig /renew
if the ip is renewed successfully, the wireless router is allocating the new tcp ip address and your network should work. Good luck.
Feb 13, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Wireless Connection
The WPA code is the password to access the router's network, so it can use your internet connection. As long as the Xbox has both the SSID and the WPA password, it can access the internet through the router.
The SSID ( Chris_PC_Network ) is mostly irrelevant to the network connection, and is purely aesthetical. Its only use is to help users distinguish between different networks (so you don't use a neighbor's network or vice versa).
May 24, 2009 | HP Pavilion dv6000z Notebook
Cannot connect new laptop to wireless network. Belkin Wireless N
The wireless settings on the laptop and the router should match. To check the settings on the router you need to access the setup page by typing 192.168.2.1 in a web browser's address bar.
By default the password is blank.
Click the Wireless tab. And take note of the SSID or wireless network name.
Go to Security, then Wireless. If the wireless security is enabled, copy the network key or security key.
On the wireless computer, you should detect SSID and if wireless security is enabled, connect to it with the correct security keys.
Hope this helps! Good luck!
Feb 22, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
No network detected to setup wireless router
You have to set a network connection on the computer. Go to the control panel and chose Network, the set a new one.
Jan 06, 2009 | Computers & Internet
Lg r 405 will not recognize wireless signal from lynksys wrt350n
hi i would suggest to access your routers setuppage and set the channel to channel 11.
make sure also if your wireless network is secured, type the correct key those things are case sensitive.
to access the routers setuppage go to a computers that is connected to your linksys router (wired) then launch IE on the address bar type 192.168.1.1(this is the routers ip) then it will ask you for username and password for the username dont type any thing for the password type admin.
when your on the setuppage click on wireless tab. while on the wireless page set the channel to 11.
after that click apply or save settings on the page.
then after that try to connect to your wireless network on your laptop.
for further help you can call linksys hot line 1800-3267114
they will surely help you with this.
hope this helps.
Oct 19, 2008 | LG X-Note LM50 Notebook
Cannot connect my wireless adapter to Belkin wireless router
Check and see if this setup guide matches your device?
Setup Guide
If it does we can probably search for more information.
Did you configure your router using WEP, WPA security (using passphrases) on your router?
Did you enable MAC address checking on your router?
Dec 15, 2007 | Computers & Internet
Try to setup home wireless network to share two home computer
Connect the home wireless network router box to the main PC through an ethernet cable with the PC powered off and the home wireless router powered off, then power on the PC & the router. Vista should locate the new wireless network and follow the windows vista network setup procedures. After the wireless network has been detected you then while the second PC's power is shut off you connect dongle adapter to the PC power on and XP will locate the new adapter. You will probably have to enter your networks pin for the connection.
Get back to me when you complete these steps.
Try next time contacting me through an online chat session. We can resolve the issue quicker while chatting together.
Nov 20, 2007 | Hawking Hi-Gain Wireless 802.11g/b...
Linksys Wireless-N WRT150N Router Logo
53 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
