Vcr hs-u500 tape won't eject
  • Poptone Dec 13, 2008
    panasonic NV-FJ620. Tape no eject drum runs few seconds then stops
  • 579 Answers
Typical belt drive failure. Take the cover off and turn the loading motor shaft with your fingers until the tape is ejected. Get a belt kit for this model and replace all the rubber parts in your VCR. Mitsubishi's are nice units and worth fixing. Check the little pulley under the capstan motor for cracks or worse.
Posted on Dec 31, 2007
Will not eject tape
take the top off the VCR, you will see where the tape is hung up. Reach down and release the tape and pick it up, now close the top.
Jul 31, 2012 | Mitsubishi HS-U575 VCR
E-2 error what does that mean
E2 means: Loading motor locked in the unload direction. Usually(not always) happens with a going bad VCR tape on the rewind. Tape is becoming too difficult to rewind and/or VCR is getting tired. Eject tape. Discard tape as soon as practical, new tapes are cheap. To clear: Hold power on/off button for 8 seconds.
May 09, 2011 | Mitsubishi HS-U575 VCR
I have a Mitsubishi HSU48. The tape is stuck in the VCR. I cannot get it out. Do you have any suggestions
I had this problem with this specific machine. These answers have all been general to any VCR. The Mitsubishi HS-U448 has its motor underneath the machine. You don't have to remove the top cover at all. Just remove the bottom plate and spin the motor (the correct direction) to completely eject the tape.
Dec 23, 2010 | Mitsubishi HS-U448 VCR
Tape stuck will not eject
open vcr look for a belt on the right side of the vcr and begin manually turning it until the tape ejects
Jan 04, 2010 | Mitsubishi HS-U770 S-VHS VCR
The VCR doesn't eject the tape
need codes for vc-aa350 is locked
Sep 01, 2009 | Sharp VC-A560U VHS VCR
Tape ejecting automatically
I found the spring on the tape carriage was off on one side. I reinstalled it and it fixed the problem
Dec 19, 2008 | Mitsubishi HS-U510 VHS VCR
Mitsubishi HS-U61 SVHS
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or have the belt replaced. Belts are inexpensive but sometimes difficult to get to. Most of the repair expense will be in the labor. Unplug the unit and take the cover off. Hopefully there will be enough clearance so you can get to the tape. Try to find the motor and belt that is responsible for operating the eject mechanism. The motor will look like a shiny cylinder, about the diameter of a quarter and will have a plastic pulley attched to the shaft. You can rotate the pulley and belt with your fingers and manually eject the tape. If the tape is around the spindles and video head, you will need to manually move the mechansim that retracts the spindles and returns the tape to the cartridge. While you may be successful in getting the tape out, you need to find out what caused the problem in the first place. Putting in another tape will most like become stuck again unless the problem is identified and resolved. Also look for a broken spring or cracked gear (missing teeth) in the eject mechanism. Please let me know if I can be of further assistance Good luck! - Jim
Feb 28, 2008 | Mitsubishi HS-U447 VHS VCR
Setting date and time on a Mitsubishi VCR
My Solution for Mitsubishi HS-U500 VCR setting the date for 2008 and beyond:
I had same problem with this old unit as everyone else has.  Since the year really doesn't matter (except maybe when you're setting to tape near a new year), here's how to get the day and dates correct:
On the remote, push Menu button, then select "First time setup", then select "Set the Clock", then select the month.  Now, start adjusting the YEAR and watch how the "days" change with the years.  Adjust the years so that the "Day" (Monday, Tuesday, etc.) matches the date (1,2, 22, 23, 28, etc.) in the month.  Then cycle thru the rest of the items and get out by hitting menu button again.
That's it!  That's my quicky solution.  Caveat: This may not be permanent with leap years and the like, so you may need to check it from time to time to make sure the days match up with the dates.  But you can do this when you go to set up for timed taping.  Hope that "FIXes" it for "Ya"!
Jan 22, 2008 | Mitsubishi HS-U595 VHS VCR
Tape ejects just after insertion
the end-of-tape optical sensor is at fault. either it is very dirty, has failed or something else is detecting end of tape. many VCR's now will auto-eject the tape upon end of tape detect
Dec 19, 2006 | Mitsubishi HS-U760 S-VHS VCR
Televison & Video Logo
532 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
