Question about Whirlpool LSQ9544K Top Load Washer
  • 1,314 Answers
How old is it do you mean the ashifting forks if its that old and still has a wig wag switch get a new one
Posted on Dec 30, 2007
Dog ate the ear cushion on my AblePlanet NC180BMM Black Noise Canceling Headphones. Can I replace?
what --the dog or the head phones
the ear cushions may be difficult to get and it may be best to get new head phones
dogs you can get from the pound
Dec 12, 2016 | Audio Players & Recorders
What can I do to help prevent my dog from getting an ear infection? I clean his ears regularly; however he still seems to be getting infections.
I found a great natural remedy that works in preventing ear infections in dogs. I use it for my dogs and they have been ok for almost a year now.
PREVENTS EAR INFECTIONS! This recipe is not meant to be used with Zymox. This should only be used once the ears are completely healed.
Keep in mind that it "will not" cure an existing ear infection.
Once you get your dog's ears to a healthy state either by using Zymox like we recommended or with the help of an antibiotic from your veterinarian, start using the following remedy weekly to prevent future infections. This works by raising the Ph level in the dogs ears.
Purchase an eye dropper bottle and the following ingredients
from your local pharmacy.
2 Tablespoons of Boric Acid
4 ounces of Rubbing Alcohol
1 Tablespoon of Glycerine
Shake the bottle before each use to thoroughly mix. Place a small eyedropper full into each ear. Cup the dog's ear and massage gently. Allow the dog to shake his head and gently blot dry any excess on the outside of the ear.
Do this weekly.
If ANY IRRITATION occurs - STOP using the recipe immediately!
Aug 15, 2012 | Pets - Others
  • 1 First you must determine the brand of washing machine you have.
  • 2 To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
    Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts.
  • 3 Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
    Buy F150 parts.
    Jun 03, 2012 | GE Washing Machines
    My dog chewed on earphone and the sound is all crackly. Is it possible to get one fixed and what would it cost?
    HI. If your dog chewed on the actual hardware and wire strands, this will not be repairable. The strands that carry the actual sound data stream have been compromised and separated from the main strand that runs through the ear piece. This type of trauma cannot be repaired, unfortunately. You will need to replace the entire ear piece set. I can understand that you want to repair and not replace, but this will be the only option in your case. You will need to replace the entire ear piece set or deal with that deteriorating sound quality.
    Aug 30, 2010 | Bose in-ear headphones - Black with...
    Agitator does not work washer goes through all the cycles it just dos not agitate model number 110.28732700 SN: CW2040704
    your agitator dog ears are worn, can get some from your nearby appliance shop or order from,,,,,not hard to replace,just pop cap off with a screwdriver then with a 7/16 socket ,ratchet and extension remove the bolt in top of agitator then lift out the dog ear assembly and replace,be sure to look at the grooves your dog ears lock onto see if they are bad
    Feb 16, 2010 | Kenmore Washing Machines
    Turtle beach x1
    Remove the four screws on the bottom of the amplifier unit. Separate the top and bottom plastics. Put a drop of alcohol into the mic switch then move it back and forth a bunch of times. This should remove the residue from the dog **** that accumulated on the switch contacts.
    Jul 14, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
    Need to get the agitator off
    that's funny [feed dogs]they are called, dog ears but you do now have to feed the dogs because their not you will have to get those parts on-line or at an appliance store.lowes wont carry those that i know.anyway if you pop the cap of the agitator you will see a piece that has a small handle.pull up and remove that piece.then you will see the bolt to remove to pull the agaitator[its a 7/16]take a good look at how its together before you take apart.......ok now that the agitator is out place on floor,put feet on the bottom piece and pull up on the top piece til comes off.then dump out the piece in the top w/dog ears in it........install new ears in that piece and reinstall upside down,inthe top piece of the agitator.then apply pressure on the dog ear retainer and place over the bottom piece of the agitate aligning the two little tabs sticking up on the bottom piece of the agitator with the little cut outs in the dog ear take your socket to place bolt back on,put some plastic wrapper or package from dogs in the socket and push the bolt into it.then place the bolt in the hole of the dog ear retainer .now lift agitator up and place onto transmission shaft and tighten bolt and place cover back on................boy that was a lot of words.that should do it for you God bless you Tiffany ,from tom
    Jan 24, 2009 | GE WBSR3140DW Top Load Washer
    Whirlpool LSQ9544K Top Load Washer Logo
    106 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
