Question about SanDisk Sansa E280 MP3 Player
FILE ISSUES i loaded over 200 songs and none of them will recognize and they delete off the player once i shut it off. how can i delete the files that wont delete too?
  • 758 Answers
You can format the whole player..and that will delete everything off the player...use windows media player to format the player....once you format you shouldnt have any songs in there...
Posted on Jan 04, 2008
Media player does not recognize that the player is empty
Have you removed the songs and it still sees them? If so, you will find a text file known as SETTINGS.DAT, or something similar. Delete it, and then re load the songs, wait for it to generate a library index.
Nov 15, 2009 | Sony Audio Players & Recorders
Tip
Song Formats for Mp3 Players Explained, Part I By Tha Mp3 Doctor I have seen...
By Tha Mp3 Doctor
I have seen quite a few threads around Fixya in which the stated problem is that the Mp3 or Digital Audio Player will not load the songs; will appear to load the songs but will not actually play them in the Mp3 player once disconnected from computer; will skip the songs on the player, or show only “0:00” for file length; songs “disappear” all of a sudden (although this particular problem can be caused for many reasons not covered in this article); your store-bought/burned/ripped CD’s will not load into your Mp3 player; or get the error message “File Format Not Supported.” All of these problems occur because the user is trying to download a song format that the player does not recognize. Every music file is in a certain format. The most common music file formats are Mp3, WMA, AAC, WAV, RA, etc. Each Mp3 player only recognizes a certain number of these formats. Every Mp3 Player is different. You will have to check your Mp3 player’s product specifications (specs) or user’s manual to find out which formats your particular Mp3 player recognizes. When you try to download or sync the wrong file format, you will get one of the errors that I mentioned above.
First things first. If you want to know what file type you have, then you must find the location of the individual music file on your computer, right click the title of the song, and select the option “Properties” from the menu. If you do not know how to do this, you will need to contact the manufacturer of your computer or go to www.microsoft.com. For all types of file except RA, RAX, and WMA, the “General” Tab under Properties will auto-populate. If your computer recognizes the file format, it will say something like “MPEG-3,” “Windows Media Audio” (Windows Media Player), “Real Audio” (Real Player or Real Network’s Audio), or “Advanced Audio Coding” (iTunes) or some other such designator. If your computer does not recognize the format, then you will just see a generic “Audio File,” and will have to download additional software. With WMA and some RAX files, there will also be a “License,” “Digital Rights Management,” or “Media Usage Rights” tab. I will explain these licensing tabs later, in the discussion on WMA files.
For every type of file other than WMA, the format error is pretty straightforward. You are trying to load a completely incompatible file format that is not recognized by the Mp3 player. To give you an example, there are currently no Philips GoGear Mp3 players that will load songs from the iTunes music service. The reason they will not transfer or play correctly is that the GoGear is that iTunes gives the users their songs in .AAC format. The GoGear cannot recognize .AAC format. To resolve this problem, you will have to convert the AAC song file into Mp3 format, or some other format that the GoGear recognizes (Note to the law-abiding: converting a copyright protected file into another format might be illegal. If you are concerned, I would just re-download the same song in Mp3 or another recognized file format – this will require a separate music service other than iTunes, in this example).
Please Read Part II for Critical Information...
on Jun 09, 2008 | iRiver H340 MP3 Player
Two problems 1)My sansa clip shut down on its own and when I turned it back on all files were erased. When plugged into the computer the media player still showed 3/4 of the memory still used on the clip...
Its not usles, you can delete the files while on the computer. After having in plugged in you can access it like a flash drive. Then you can open the music folder and delete as you will. Depending on what kind of files you have on it, its possible that i wont recognize the format of the file. I think though from what you've said that it did work, and then stopped playing songs that worked before. So I don't know what to do about that. I don't use the normal way of loading songs onto my Sansa clip MP# player though. I just dump all of my songs via direct transfer into the music folder in the player itself
Oct 04, 2009 | SanDisk Sansa Clip MP3 Player
SAmsung YP-K3 MP3 player - Corrupted library ? cannot delete songs or synch
i would like to download other songs but i dont know how?and i have to delete all of them!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Oct 09, 2008 | Samsung YP-K3 MP3 Player
Songs won't go on mp3 player.
By Tha Mp3 Doctor
Sep 20, 2008 | Audio Players & Recorders
How do i delete music off my sansa mp3 player?
Source: http://www.ehow.com/how_2023687_delete-files-sansa.html
Step 1Connect the USB cable to your Sansa MP3 player, then hook the other end to a free USB port on your computer. Step 2Give the computer time to recognize the Sansa MP3 player. Once it has, double-click on the MP3 player’s icon to view the music files stored to memory. Step 3Scroll through the list of audio files until you find the ones that you wish to delete from the Sansa MP3 player. Step 4Click on single items or click and lasso multiple files. Step 5Right-click on the highlighted files to pull down an action list and from there select Delete. The computer will ask if you really want to throw the file away. Select OK. Step 6Exit from the window, then disconnect the USB cable from the Sansa MP3 player. The player will automatically turn off. The memory will update the first time you turn the player on after deleting songs. Tips & Warnings
  • Optionally, you can left-click on a file and drag the file icon to the Recycle Bin. Either way, you can delete music that you don’t want from your Sansa MP3 player.
  • Unlike other documents and files, once the music file hits the Recycle Bin, it’s gone. Make sure that you are deleting the correct file.
For more help: http://www.supportrix.com/
Jul 30, 2008 | Audio Players & Recorders
How do i delete songs from my mp3 player?
Mp3 Players rarely if ever hold as many songs as they advertise - the numbers on the box, spec sheets are "ideal" numbers based on unrealistic 2-minute long songs all in mp3 ultra-compressed format. Although there are exceptions, I have found that, in general, 6GB = 1000 songs, 2GB = 400 songs, 1 GB = 200 songs. Very long audio files, audio books, etc will throw these numbers WAY off.
MyMusix's PD-6030:
If you are using Windows Media Player 11, go to the sync tab and make sure it is displaying only the files on your Mp3 player, and not every file stored on your Computer's hard drive. Click once on a song you want to delete, and then hit the delete button on your computer's keyboard.
If your not using Windows Media Player 11, then read pp. 17-20 of your user's manual, available at www.mymusix.com
-Tha Mp3 Doctor
Mar 18, 2008 | MyMusix PD-6030 MP3 Player
Mp3 wont download songs
Re-sychronize your music files with PC using Media Player 10 if "License Expired" or cannot find license message. Once I completed this..it let me syrchronize file to the MP3 player
Jan 22, 2008 | iLO MP3 Player
Mp3 player
hello:
My mp3 player is creating a problem in deleting and saving songs from memory.. Whenever i tried to delete any existing file,, it deletes its once..but when i reopen. i find the same file in the library.. And when i tried to load anything in it..it stop in the middle of downloading..
I m nt getting where is the problem ? I tried to delete whole files from my mp3 players but some fles are nt getting deleted..Can anyone help me in this matter please ?
Jan 21, 2008 | iLO MP3 Player
Sansa e260 How to delete songs ?
This MIGHT fix the problem: Make sure that Windows Explorer is set to show hidden files and folders. In Windows XP, click TOOLS, FOLDER OPTIONS, VIEW and make sure you have selected "Show hidden files and folders".
Jun 15, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
44 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
