Question about Linksys Wireless-G WRT54G Router (DSLSWRT54G)
Wireless on pc will not connect
I have a wireless WRT300n i did my configuration ok, my wireless on my first pc that has windows vista is working fine but the one with window xp is not working i put in the wireless card.the computer recongnizes the card, but after loading the card driver nothing happen
  • john hors
    john hors Dec 30, 2007
    thanks, but i try that it did not work.i might have to reload the pc. the same card works in another pc.
    Sergeant:
    Champion:
  • 310 Answers
Does it see it in the device manager? check your network conections. did you load the software as directed and allways reboot with everything hooked up
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Dec 30, 2007
    Problem Solver:
  • 9 Answers
What you should do is try another card on that computer and/or try the current card on another computer just to see if it is the PCMIA Card's problem
Unable to use the wireless setup wizard - I am trying to connect my pc with my wireless printer. When I try to use the setup wizard on the pc it says depending on the wireless software installed on this pc...
The Wireless Network Setup Wizard and the View Available Wireless Networks feature both rely on the Wireless Zero Configuration service to provide their functionality to Microsoft Windows XP Service Pack 2 (SP2) and Microsoft Windows XP Table PC Edition 2005. If the Wireless Zero Configuration service is not available, you receive an error message that directs you to this article. This behavior occurs for several reasons. Some computer and hardware manufacturers provide their own configuration software that replaces the Wireless Zero Configuration service that is provided in Windows. In that case, you must use the software that is provided by the manufacturer to configure your wireless network. If you want to use the Wireless Network Setup Wizard or the View Available Wireless Networks feature to configure your wireless device, see the documentation that came with your computer or with your wireless network card. Use this documentation to determine whether you can use the Wireless Zero Configuration service to configure your wireless network. Sometimes, you cannot use the Windows functionality.
If your computer or your wireless network adapter did not come with its own wireless network software, follow these steps:
  1. Click Start, click Run, type ncpa.cpl, and then click OK.
  2. Click Network Connections.
  3. In Network Connections, click to select your wireless connection, and then clickChange settings of this connection.
  4. On the Wireless Networks tab, click to select the Use Windows to configure my wireless network settings check box.
To start the Wireless Zero Configuration service, follow these steps:
  1. Click Start, click Run, type %SystemRoot%\system32\services.msc /s, and then click OK.
  2. Double-click Wireless Zero Configuration.
  3. In the Startup type list, click Automatic, and then click Apply.
  4. In the Service status area, click Start, and then click OK.
If you receive an error message when you try to start the service, see the "References" section for more troubleshooting information.For more information, click the following article numbers to view the articles in the Microsoft Knowledge Base: 815485 Overview of the Wi-Fi Protected Access (WPA) security update in Windows XP 313242 How to troubleshoot wireless network connections in Windows XP
Feb 26, 2010 | Acer Aspire One PC Notebook
Can't connect to wireless router. Had internet till router changed. All other laptops in the house work fine. Diagnosis says windows is not managing the network, what happened?
when you try to connect to the wireless network, you are getting the message " windows can not configure the wireless network" or windows is not managing.
What is the Operatig system on the computer ?
If it is windows XP then you can switch over to windows utility.
for this you will need to start the wireless zero configuration.
If it is WINDOWS VISTA / 7, then windows will manage the network.
Click here for more information about routers and wireless network.
Jan 24, 2010 | Computers & Internet
Trying to install wireless network. Wireless
if you're using windows XP then you need to start the Wireless Zero Configuration. just click on the start button and choose run then type in services.msc in the run box and click on ok. in the services window just look for Wireless Zero Configuration, it's at the bottom part of the list. just double click it and under the General tab you'll see a box for the Start up type, just set it to Automatic and then on the Service status click Start and then Ok button. once you finish this, you will be able to see the Wireless network tab to be able to select the "use windows to configure my network". in case you're using vista, that option is actually not available as it automatically starts the windows wireless manager and only conflicts if there is a third party software/ wireless manager installed in your computer.
hope this helps...
Nov 24, 2009 | Dell Inspiron 2200 Notebook
Zero wireless configuration has been disabled on presario
Follow this procedure to stop and start the Wireless Zero Configuration service in the Windows XP Operating System:
  1. Click the Start button, then click Run .
  2. In the Run window, next to Open , type cmd .
  3. Press the ENTER key.
  4. In the Command Prompt window, type net stop wzcsvc .
  5. In the Command Prompt window, type sc config wzcsvc start= auto .
  6. Press the ENTER key. NOTE: The [SC] ChangeServiceConfig SUCCESS should be displayed.
  7. Type net start wzcsvc .
  8. Press the ENTER key. NOTE: The Wireless Zero Configuration service was started successfully message should be displayed.
  9. Type exit .
  10. Press the ENTER key.
Jul 29, 2009 | HP Computers & Internet
Windows vista to windows xp sp2; the VGA and wireless don't work
uninstall the wireless driver and then reinstall it again and then install the vga driver and do the wireless configuration from the router page,and then try and install the wireless driver of xp and also install the vga driver of xp.......good luck.....
pls rate this solution
Feb 16, 2009 | Microsoft Windows Vista Home Premium with...
Unable to connect to wireless internet
You may need to start the wirless zero configrations...
you havnt mentioned your OS..
any ways here is the way to turn it on...
for WIN XP
Windows XP Windows XP users must have Service Pack 2 installed to activate the Wireless Zero Configuration. ( How do I check that? )
  • Go to Start and Control Panel
  • Click on Administrative Tools and Services
  • In the Services box scroll down the list of Services (Local) until you find the one labelled Wireless Zero Configuration and double click it.
  • In the Wireless Zero Configuration Properties (Local Computer) box change the Startup type to Automatic
  • Click on Start and once the service has started click on OK
  • Now find the service labelled WLAN AutoConfig and double click on it
  • In the WLAN AutoConfig Properties (Local Computer) box change the Startup type to Automatic
  • Go to File and Exit to close the Services window
Windows Vista
To start Wireless Zero Configuration in Windows Vista you need to log in as an Administrator.
  • Click on Start and Control Panel
  • Select Administrative Tools and then Services
  • In the Services box scroll down the list of Services (Local) until you find the one labelled Wired AutoConfig and double click it.
  • In the Wired AutoConfig Properties (Local Computer) box change the Startup type to Automatic
  • Now find the service labelled WLAN AutoConfig and double click it.
Let me know if it helps...
rate me .....
Best regards
Tanveer Ahmad Khan
Dec 14, 2008 | Acer Aspire 3680 Laptop
I had to restore computer settings and my wireless G Notebook card is not working....
What operating system you had and whether you got a windows based system like xp or vista you have a restore option in your system tool sun the restore and get back to a previous days which everything works fine but in your case i hope you have to check from the wireless switch and the device driver for the wireless card, if status for both are ok check for wireless zero configuration service running under administrator tools /services
Jul 05, 2008 | Belkin Computers & Internet
Wireless connection of netgear wireless router for compaq laptop
When you look on the box that the router came in, you have to look to see what Operating Systems it is compatible with. In many cases, routers will not be compatible with vista. I have a Linksys WRT300N, and it works great with Vista.Hope this helps.
May 04, 2008 | NetGear WGR614 Wireless Router
Local access only
hmmm... with those settings, the Vista machine SHOULD be working...
when you open internet explorer on the vista machine, can you go to tools, internet options, and then the connections tab?
along the bottom there should be an option for lan settings. click on that, and then make certain that 'automatically detect settings' is checked, and that everything else is blank.
then restart internet explorer.
what sort of error message do you get now, if you try to go to, say, www.cnn.com?
Mar 26, 2008 | Linksys WRT300N Wireless Router
Linksys Wireless-G WRT54G Router (DSLSWRT54G) Logo
60 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
