Question about Electrolux Lux 5500 Canister Vacuum
Stuck sock i have a sock stuck in the handle right where it curves from the hose...i tried a wire hangar but it doesn't budge...does the handle detach from the hose?
  • 75 Answers
Don't put a hanger in there.... Call your local Aerus Service Center and they can remove it for you . If they tear the hose its their responsibility to replace it. If you tear it you are looking at $119.99tx at least.
Posted on Jan 12, 2008
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
First off how did u get the sock that far..lol but yes it (can but it is a pain and u chance tearin the hose but if ufeel like u have to better get a roll of duct tape just in case)but i would try the coat hanger a little more put a bend at the very end of hanger hook the sock and pull
Posted on Jan 06, 2008
There is a sock stuck in the hose of my dyson dc23 animal motorhead how do I get it out
Hi, this is Jim with Crucial Vacuum,
Detach the hose and stretch it out completely, if the sock is in a hard to reach place use a broom handle to push it out. Be careful to mind the edges of the hose you don't want to cause a tear, which would lead to poor suction.
You can purchase replacement parts for your Dyson DC23 direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dyson-dc23-pre-filter-part-913394-01.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
May 08, 2015 | Dyson DC28 Animal Upright Vacuum New DC 28...
How can I separatte the ****** handle of my Epic 6500 fromthe hose? I have a wrapped pair of socks stuck in it at the handle
There are two different styles of hose for the 6500 vacuums. Please be careful when you take the handles off and also when putting it back togeather. To remove the handle there are two screw caps that you need to remove to get to the screws. You can do this with the tip of a knife or something similar inserted under the edge of the screw cap and pry up. The screws can either be a Phillips head or a torx bit. Remove the screws and then separate the top part of the handle from the bottom. Make sure to notice the position of the wires and do not unplug them from the switch or the contact block.The contact block at the hose end of the handle has two contacts that transfer the power from the hose to the handle and will bend out of shape if you are not careful. To remove the contact block, use a flat head screw driver under the block and pry up. On the older models, the handle will slip right off. If you have a newer model, there is a handle retainer at the base of the handle and will push out with a screw driver. It only goes one way and
the handle will slip off.
To replace the handle just reverse the procedure. Good luck.
Aug 28, 2014 | Electrolux Epic 6500 Vacuum
Why does the full bag indicator not work
Usually means there is something blocking the suction (like something stuck in the hose). Try taking the hose off and turning the vac on. If the indicator doesn't go to full now but does when the hose is on, something is in the hose. Usually it's right in the curve of the handle. If your model has a suction relief on it, try opening it up and looking in there. You can also put the hose on the exhaust and try to blow out what is stuck but do this outside as it can get messy.
Aug 17, 2014 | Miele Vacuums
Was using vacuum and sock is now lodged in vacuum hose. How can I get the sock out?
The easiest way to remove an article of clothing from the hose is to remove one end of the hose from the vacuum, and reach in with a piece of wire with the end bent into a hook. A wire coathanger will work well for this. Just straighten out the coathanger, take a pair of pliers, and put a small bend at the end of the wire, in a J, or hook shape. Then, reach the wire into the hose, and when you feel the obstruction, twist the wire, so that the hook gets stuck on the sock. Then, pull it out, and reattatch the end of the hose back on the vacuum.
It doesn't matter which end of the hose you remove, just whichever is easier, and hopefully closest to the clog.
Do not try to push it out, as it will just bunch up tighter. It must be pulled out.
Jun 17, 2011 | Kenmore 31913 Progressive Direct Drive...
Sock stuck in hose midway. Unable to getit out with wire or brrom handle. Is there a way to take hose apart at either end.
If the sock is midway, taking either or both ends apart won't help. Take it to a vacuum repair shop and ask them to try to unplug it. You may need to buy a new hose.
Feb 22, 2011 | Kenmore 23913 Progressive PowerMate Bagged...
I need help removing a cat toy from the handle that connects to the hose on my vacuum? The ball seems to be stuck in the curve or just below the curve before it enters the hose.
The handle needs to be removed to do this. Taking the handle apart and especially putting it back together can be tricky, so I recommend taking it in to an authorized Aerus Electrolux store to have the item removed. If you don't put it back together properly, it could result in an electric shock, and even a fire. I have seen a totally melted hose from someone trying to dig out an object, then the hose wiring shorts out and lights up.
I dislike having a disassembled machine or part brought in to be reassembled, and finding a broken tab that requires replacing the handle or part that's brought in.
Be safe, please take it to the shop.
http://www.aerushome.com/storelocator/
Dec 17, 2010 | Electrolux Lux 5500 Canister Vacuum
My Dyson DC20 motorhead vacuum has a blocked hose - how can I unclog this? I think there is a sock caught up by the handle. The hose has electrical wires running through it so I cannot cut the hose.
Usually a plugged hose can be cleared using a broom handle, if you can force the blockage through, if not as previously suggested a coat hanger attached to the broom handle (duck tape will do) straighten out hanger so it can be used like a cork screw to screw into the blockage and pull it out, socks,underwear and pantyhose are the usual suspects!
Nov 06, 2009 | Dyson DC05 Cylinder Bagless Canister...
No suction for use of crevice tools, running hot, then shut off
Obviously no suction in hose would indicate a blockage, over heating is a breaker that shuts off the machine when it over heats. There is no way to clean hose the on this model because the hose does not detach at either end, therefore I had to employ the use of the good old wire hangar. Job complete up and running, with good suction. It is amazing what a prayer to God can do.
Nov 17, 2008 | GE 106766 Bagged Canister Vacuum
Sock stuck in hose
Yes there is a small clip on the purple/yellow part on bottom of hose. its hardly an inch thick pll back on the tab and up on the hose
Oct 28, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a sock stuck in the hose of my vacuum cleaner. Rennaisance canister model. Because of the design of the handle I can't utilize the reverse blower. Please advise. Thanks
lol
Try taping a fishing hook or some such onto the end of a straightened out coat hanger. See if you can push it up the hose and hook the sock.
Or, remove the hose entirely, and push a broom handle down the hose.
That's all I got...
May 07, 2008 | Vacuums
Electrolux Lux 5500 Canister Vacuum Logo
292 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
