A common occurance is blockage of the water pump propellers. Check your machine's manual to familiarise yourself with the drain filter.
Please note by openning the filter, the existing water in the machine will drain out on to the floor. Be prepared for this with towls and mops.
Clean out the filter. Use a torch to look into the cavity and make sure nothing has gone through the filter to the pump propellors.
Once the filter is clean and all the water has drained out. Start the machine on spin cycle. If you can hear the water pump working then all should be well. If there is no sound from the water pump, it needs replacing or further investigation by a technician.
Good Luck.
Ash
Was this helpful?
Yes
No
Popular Solutions for GE WBVH6240F Front Load Washer
Water pours out from under the machine at initial fill. I can see it coming from the little valve...
(More)
Water pours out from under the machine at initial fill. I can see it coming from the little valve inside above the door....not necessarily the main fill valve on the left.From underneath I can see it running down the counterweight in the front of the machine. This is not a small leak, it runs out on to the floor as fast as it is filling.
