No volume volume deteriorated over 6 months
  • 1 more comment
  • Anonymous May 19, 2008
    had TV for less than 3 months and no volume?
  • lanajen Jun 06, 2008
    I'm guessing we have also had our tv for around six months and, at full volume, we can barely hear it from 3 feet away.
  • Anonymous Jul 17, 2008
    Have philiphs tv picture is clear but no volume is not working
Full volume what a JOKE, you can bearly hear it and if air conditioner is on....you get to just read lips!!
Posted on Sep 05, 2008
What is causing it to leak on the hot water side?
The connection may have deteriorated while the machine sat idle. Reconnecting with new washers may solve the problem.
Oct 29, 2015 | Washing Machines
How do I fix my viso 65 inch smart tv when the volume just turns itself up tv is only 6 months old
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 10, 2014 | Vizio Televison & Video
I got an oil change and a week later caught a flat and dead battery, it sat for 3 months in front of my house (wintertime), now I want to fix it, will I need a new oil change?
Yes, it is okay. Unlike fuel settling and separating, the oil does not change as much. The chemical additives in oil can start to deteriorate after 6 months, but most of the changes occur due to water vapor condensation from the cool down from running.
The best thing for your car now is to add a fuel additive like Heet" or another form of "Drygas" which helps get the moisture out of the gas.
Please rate my info.
Jan 29, 2013 | Buick Cars & Trucks
Our small office purchased a Canon Imagerunner 2000/1600 copier 4 years ago. Since our last service call, when the drum was changed and the machine was cleaned, we then ran less than 2000 copies. The...
When your drum was replaced did they put in a new drum assy or just replace the drum cylinder? I would purchase a new drum because these are one of the chepest to buy, around $ 80.00. They have a 6 month warranty and around 20,000 copies. I would replace the drum to see if that solves the problem. Before doing that, pull off the left side bypass assy. It is easily removed without tools. You should be able to see the drum and see if the drum is clean. If not, then replace the drum unit assy. Are you using only Canon toner, no other kind of brand will work. Generics should work but they are usually not as good a quality. The volume is very low and that should not be an issue. I believe its suppossed to handle 10,000 copies per month. Cleaning the glass top and below may help. The mirrors should also be cleaned as well. Good luck.
Dec 01, 2010 | Canon imageRUNNER 2000 Copier
We have 6 month old Philips LFH9380s where the quality of recording has deteriorated - words are merging together and becoming unintelligble.
Hello if you are using your unit for dictate you probably need to change the mini tape but if you are using your unit for transcribe just clean the head with Alcohol you can purchase mini tapes for your unit at http://www.tvps.com/Departments/Dictation-Accessories/Cassette-Tapes/Mini.aspx
Nov 09, 2010 | Philips LFH-720
Sound volume is very low on incoming calls. Have set volume to max in settings and still no difference!
Send your phone to service, my nokia is dead too, so far 6 friends that have NOKIA TOUCH mobiles 5230, 5530 and 5800 all of them lasted around 6-8 months before the sound from incoming calls is very low with all the settings on volume set on high.
Things that will NOT fix the problem: Reseting phone, isntall up to date software.
BEST SOLUTION GET YOUR PHONE TO SERVICE
Oct 04, 2010 | Nokia 5230 Cell Phone
Chasis was replaced 5 months ago. Set turns on
Contact Mitsubishi immediately. They will warrant the chassis for 6 months.
Sep 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Speakers have crackling sound
usually, crackling is due to 3 things:
1) the soundcard (or sound device you have them plugged into)
The best way to test this is to plug in another set of speakers or a headset directly to the sound
device, and listen. if you don;t hear the crackling, than consider that idea scrapped.
2.) speaker wiring/cables. Check the wiring for cracks/frayed spots. Do you get any crackling during/after you move the wires? if there is ANY change, for the better or the worse, than you have your culprit.
3.) the speakers themselves. when the first two options above are exhausted, there's only the insides of the speakers themselves to blame. you might not have seen any cone deterioration- but other things could happen, such as deteriorating wiring, etc.
for new speakers, they are relatively cheap- Here in Canada at least, I can get a new 2.1 set for anywhere from $25-60. Although, I'd strongly recommend any of the Logitech brand speakers- most models have subwoofers with unbelievable bass (for the price) through them. I myself have the more expensive Z-5500 series from them (5.1), and I've been more than impressed.
Sep 30, 2008 | Audio Players & Recorders
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
