Standard Televisions
Problem for Standard Televisions
Generic problem for all Standard Televisions
TV video problem
By Kilohana on Dec 30, 2007
I have two TVs both started showing a thin compressed picture in a horizontal line across the screen. I have used different cable outlets, disconnected all my other equipment but the problem persists. My smaller (and older) Sanyo will occasionally work for brief periods but there is nothing consistent going on. Cable guys came out and said it is electrical interference...what now?
Same Problem
Mar 15, 2008
-   II have a hitachi 36 tv it started showing a thin compressed picture in a horizontal line across the screen.
i read the below solution and will be looking to send it out for repair. any ideas or help? miltonousland@yahoo.com-   miltonisdead
Best Solution
posted on Dec 30, 2007
Helpful)
salt56
Rank: Guru
Rating: 89%, 132 votes
If you have intermittent line horizontally across both tv screens then there is likely to be bad solder connections on the vertical ic's of both of them. This can be fixed by taking the back off with quarter inch nut driver and carefully sliding the chassis out and turning it up to see the solder side. I don't know the location numbers but the vertical ic will be mounted on a metal heat sink and the connections will be in a row. Sometimes you can see the bad connections. You may need a magnifying glass. I recommend someone who has experience soldering electronic circuits. No solder bridges etc. This is for intermittent (works sometimes) problem on vertical ic. If the line stays then the chip ic is bad along with a 1 ohm resistor off the flyback high voltage transformer. From what you described you likely have bad connections. Hope this helps
Was this helpful?
Yes
No
Popular Solutions for Standard Televisions
Questions and Unsolved Problems for Standard Televisions
Answer
cannot get tv to recognize direct tv box something was pushed on controller
Answer
sony kv 1435m3 does sound ic out of order again and again also turns off the tv set after 1or 2... (More)
Answer
I can't turn off the closed caption on my sanyo tv. I do not have the remote. The model number is... (More)
Answer
have a jensen universal remote need the code to program it to sansui tv
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
in , TX
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
