been setting in storage a year when all hooked up it starts up just fine then quits and sets there with the timer running but wont wash or spin or nothing wont fill with water
When you mention that it starts up fine. Do you mean that the machine initially takes in water, but then nothing after that. Or does it simply power on, but no water comes into the machine.
If no water comes in initially, then it is most likely your inlet valve.
If water comes in but no motor action, then it could be a raft of things. Disconnect the power source. Open the top hatch and the back panel. Make sure the drive belt has not come off during transport. Also check to see if no wiring connection has come loose. NOTE: Make sure the machine is off and disconnected from the power plug.
If you can't spot anything loose then it is best to get a service technician to diagnose the problem.
The door latch end snapped off and now the end is sitting inside the door lock assembly. A new part...
(More)
The door latch end snapped off and now the end is sitting inside the door lock assembly. A new part is cheap and was ordered, but we cannot get the piece out! We called Frigidaire (Electrolux) and they could not help and would not provide a way to get a manual where we could see how to disassemble. Can anyone provide some advice? THanks!
water continues to enter the frigidaire gltf2940eso until too full and door opens and water spills...
(More)
water continues to enter the frigidaire gltf2940eso until too full and door opens and water spills out-sensor, door magnet?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
