Question about Navman NavPix N40i GPS Receiver
Cannot switch navman on
Does it need a memory card in place
  • Anonymous May 04, 2008
    My navman n40i turns on but does not start up please can you help me.
  • axlo Aug 12, 2008
    Turning the Navman 40i on when using its own battery
I have a S30 Navman I was using it , when I got to my destination I turned it off when I went to turn it on to go back it will not turn on no picture or anything
can you help me please thank you
Posted on Jun 29, 2008
No you dont need a memory card, as long as the battery is charged, press the power on button down and it comes on
Posted on Jan 03, 2008
Remove memory and put it back, if it still does not work memory is probably faulty.
May 24, 2008 | Navman F20 GPS Receiver
F20 navman error
You need to remove the 2 screews from the bottom and then gentley prize the unit apart from teh bottom using a blunt broad knife will help if you cant have the plastic case splitting tools which are used in the trade,
then once apart the same side where the power button is you will see a microsd card its the same as in a mobile phone just pull it down from the top (its hinged at the bottom) then make sure the card is in correctley and then close it back and test (b4 putting the case back on) that will fix it we ahve a lot of these coming in and its where its been dropped etc and jumps out thats it
from fototime. co .uk
Oct 29, 2008 | Navman F20 GPS Receiver
Navman f20
please remove the memory card and try it ..if it work's may be memory card be corrupted..
Sep 02, 2008 | Navman F20 GPS Receiver
Navman F10.........Just Out Of Warrantity
hi sir,,
may be memory card correpted..
Sep 01, 2008 | Navman F20 GPS Receiver
Navman n60i how to replace battery
Do i need to keep power to my Navman N60i as i change the battery,or is it ok to remove the battery and place the new one in. Will i wipe out the memory.Thank you.
Aug 30, 2008 | Navman NavPix N60i GPS Receiver
Error message on Navman Navman F Series Failure Unable to detect internal memory. Please return the unit to dealer. Can anyone help?
I have a F20 here I am currently tring to fix.
The error comes from the internal memory card being faulty.
It is only a micro SD car.
It may be totally usesless, or need re-programming via the USB port.
You can download the firmware, and it fixes a working MicroSD card.
If your card is damaged, then you will have to replace it, and strip the F20 down to do so.
Then you can upload the firmware.
I warn you, though.
Stripping it down is a bit tricky.
I replaced this F20 memory card, and put on the firmware, but have a new error, that it cant find any maps installed.
Hope this helped you
Jul 14, 2008 | Navman F20 GPS Receiver
Info on fitting a new battery to Navman PiN570
Remove SD card and place the Navman on a soft surface face down so that you do not scratch the LCD screen. - Take out 4 screws ONLY. 2 under the gps antenna and two hidden black discs at either side of the bottom on back of unit,Make sure you use a small Philips screwdriver.
- Use your finger nail very carefully around the edges, go extremely slow to detach the cover. Once it opens, make sure of the Power switch button, they seem to fall off.
- Remove clear tapes at the battery connector. DO NOT pull up the connector, you need to pull sideways and make sure do not use excessive pressure while pulling.
- Place the new battery in same manner and also place battery cables neatly so that the do not come in the way while closing the cover. The LCD display should turn on. If it does not, look at the Battery connector and make sure it is all the way in.
- Put the cover back slowly and then make sure nothing is dangling along the edges. Do not forget to check the Power Switch button; it should be in proper place. Press the cover firmly, it should snap in place.
- Charge the battery fully before using Navman.
- Insert SD card. You may need to reload Navman application software or restore from SD card, if you stored on the SD card previously.
May 16, 2008 | Navman PiN 570 GPS Receiver
Set up for navman se
I have a NAVMAN SE and I want to use it with my iPAQ 3630, also what sort of card do the NAVMAN take to store it data
Jan 17, 2008 | RIM BlackBerry Pearl 8100
Navman NavPix  N40i GPS Receiver Logo
251 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
