Question about Canon imageRUNNER 210S Copier
Canon imagerunner 210s
When I turn the copier on I get E000 error and message to turn off and on main power and nothing happens, can you help?
Thank you,
  • Canon Master
  • 1,113 Answers
EOOO is a thermistor-fuser error. Your machine will need a fuser, but on occasion a power surge can trip the error, E000 needs a code to reset it, I dont know if same but this is the code on a IR 330s
Press the userbutton then press "2" & "8" at the same time and then press userbutton again.
You will now enter servicemode
press " Copier "
press "function"
press "Clear"
press "Error"
leave servicemode by pressing resetbutton twice.
restart machine.
Mind you it is only a reset, if fault still exist it will go eooo again confirming that it needs a new fuser unit.
Posted on Dec 30, 2007
Fixing malfunction. Thermoswitch or film unit.
Jan 20, 2012 | Canon imageRUNNER 210S Copier
Image runner 210s error code E000. What to do?
Your problem in the fuser unit.Check and clean the fuser unit component parts:thermistors,thermofuses,verify the continuity of the heater lamp,and verify the upper and lower fuser roller mechanical.
Nov 24, 2009 | Canon imageRUNNER 210S Copier
E000 error message on canon imagerunner 2000 copier
E000 means :
"The main thermistor reading does not reach 40oC 14 sec after the fixing heater goes ON (fixing low temperature error)"
Jan 19, 2009 | Canon ImageRunner 1600 Copier
Solve System Error E001
it needs a new fixing unit. Youll need to call a tech for this, the finixing unit cost the dealer 180 bucks and the make up is around 50% so its not a cheap unit. There also adjustments that need to be made in service mode so you really need a Canon tech that knows how to get into the service mode and make those adjustments for the new part.
Jan 16, 2009 | Canon imageRUNNER 210S Copier
Error E000
First of all a E000 is a power proble that the fuser is not warming up in time or power is not avaible. Is it possible that you may not have a outlet just for the copier by it self.... It could be low on usable power. If the power is good, I would say that your Upper heating unit is shorting out from time to time. You will need to have to replace the fixing unit if it is to much of a pain to deal with.
Jan 05, 2009 | Canon imageRUNNER 210S Copier
Canon 330 image runner Error code E000
E000 is a fuser problem.
take out the fuser (this is where the paper exits and gets hot) the tow long big rollers, the lamp may have blown or the thermofuse (keeps the copier from over heating and going to meltdown) may be bad.
The newer ones (not sure about this model ) have a ceramic instead of a heat lamp and also a thin brown film instead of rollers.
if it has a film make sure it is not torn or displaced.
Nov 21, 2008 | Canon imageRUNNER 210S Copier
Getting a eooo mesage
E000 error is due power surge or electrical fault within the copier. you can clear the error in service mode.
Sep 30, 2008 | Canon imageRUNNER 1630 Copier
Ir 2000, system error E000
The main thermistor reading does not reach 40°C 14 sec after the fixing
heater goes ON. (fixing low temperature error)
If E000 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and
turn off and then on the power switch to clear the memory: #7
Entering service mode: press "aditional function" and after "#(ID)"
Jul 16, 2008 | Canon ImageRunner 1600 Copier
Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
May 17, 2008 | Canon imageRUNNER 1600 Laser Printer
Canon imageRUNNER 210S Copier Logo
280 people viewed this question
old marine
old marine
