Question about Nikon D50 Digital Camera with 18-55mm Lens
D50 not taking pictures
I am a novice. I left my d50 in the car, and it had a little condensation on the lens. So, I rmoved the lens and wiped it off. then, replaced it and now, the shutter sounds different and it will not take pictures. One thing I did do was push the shutter while the lens was off. HELP please.
ak
Okay this is how i fixed mine. take the lense off and hit the button to take a picture the shudder should snap down up down or something like that
or lift up the shudder and see at the very back there should be a little black almost curtan like thing. make sure there are no bends or breaks or bubbles the curtan things.
hopes this helped
Posted on Mar 06, 2008
Not experienced on this but if not taking pictures it could be the `mirror ` is not moving have you tried taking off the lense again and re fitting, you may not have fitted properly.
My own opinion is that pushing the shutter shouldnt cause a problem. Do the white dots line up?
Wish I could be of more help.
Posted on Jan 02, 2008
Nikon d50 takes black picture w/ lens cap off
Sounds like a settings issue please provide more information such as what is your camera set at; ISO, Shutter speed, F-Stop & how are you using it, manual mode. Aperture priority, shutter priority or Auto? I would need this info to further direct you in trouble shooting your issue.
Apr 12, 2014 | Nikon D50 Digital Camera with 28-80mm Lens
Aperture lever sticks on nikon d50 and auto setting doesn't work.
Look kid, you are a menace to a camera, no oil, drilling, or sanding
call Nikon they can help if not $400.00 can get you a D3100
Aug 16, 2012 | Nikon D50 Digital Camera
My Nikon D50 will not take pictures
Well if you charge for 24 hours and wait about 2 minuts try it then but if it doesnt get a new camra
Jun 27, 2012 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon d50 camera will not turn on. Batteries are fully charged. Camera has not been exposed to extreme hot or cold Camera has not been exposed to water or other liquids
Does the readout come on at all with a card in it (no. of exposures left)? Try cleaning the contacts on the battery with an eraser and wipe down with alcohol wipe.
Apr 01, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Mark on photos - dirt on sensor?
It is possible and quite easy to clean the sensor yourself with a little preparation. First, Google the words...cleaning an slr sensor. You will find sites that will explain the procedure in detail with pictures. You will also find out what materials you will need to purchase. Get these and have no fear!!! You can do this.
Dec 26, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
D50 reads f-- and wont take pictures
What lens? Either you have a non-CPU lens which requires that you use it in Manual (M) mode, or it's a CPU lens and the contacts aren't engaged properly. Remove the lens, clean the contacts, reattach the lens, and jiggle it a little to seat the contacts.
Nov 11, 2009 | Nikon D50 Digital Camera
Nikon D50 While shooting pictures the shutter button stopped work
TURN ON CAMERA. SEE IF THERE IS A MESSAGE. NOW, TURN OFF CAMERA. TAKE OFF LENS. REPLACE LENS- MAKE SURE YOU HEAR A "CLICK" TURN ON CAMERA AND TRY AGAIN. OK?
Mar 03, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 Set Problem - Won't Take Pictures
The F-- error means that the lens is not communicating or has lost communication, with the body. I would first try cleaning the contacts on the lens and body. You might also try another lens. This problem has been known to develop when using a heavier, large lens. It seems like you have had the unit for a number of years. Has this always been an issue?
Hope that helps,
-WN
Aug 31, 2008 | Nikon D50 Digital Camera
Won't Take Picture Sometimes
I have the same problem with my D50. I believe it is caused by poor electrical contact between camera and lens. The contacts may be dirty but I have tried cleaning them and I still get the same error. Moving the lens often solves the problem. This led me to suspect that it is due to slight wear of the plastic mounting bayonet on the lens. This allows the lens to fall slightly and disengage from the contact pins. My 70-300mm lens has no problems since it only uses a few pins.
Mar 21, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 Digital Camera with 18-55mm Lens Logo
74 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
