Question about Mitsubishi WS-65909 65" Rear Projection Television
Mitsubishi ws-65909 On my ws-65909 when I turn on the unit there is a green arc across the picture from right to left top of screen only.
  • sue1238 Jan 22, 2008
    The image is stretched and doubled. There is a green band/ arc across the top of the screen. The colors are also off.
    President:
  • 4,402 Answers
I suspects you have bad convergance IC's
It takes a good tech around 3 or 3 hours to take the old ones out and solder in the new ones. Also, it is likely one or two resistors are burnt and will need replacing as well.
Don not run the tv till you have it fix you will cause more damage!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 04, 2008
I have a Mitsubishi 55"
This set has a convergence problem. You should only need to replace the IC. Part is STK393-110. It sits on the middle board behind the large heatsink. Use a heat transfer compound to ensure repair lasts. If you have no experience soldering (or unsoldering) please use a professional for the work. The traces are fragile and I have fixed many mistakes local DIYers have committed. Goodluck.
Jan 20, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I've a mitsubishi ws-65909 and the picture is out of synch. Went to the convergence menu and I'm unable to get the blue in line with red and green and the blue convergence grid can't seem to be realigned....
Hi my name is Roety,
I can help you with your issue ,
If you can solder you can replace the Convergence ICs
A repairman would charge about $400 to do it for you
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Dec 06, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Ws-65909 picture and sound are fuzzy, will a new power supply fix it???
It does not sound like a power supply problem. Most of the boards for this set are no longer available from Mitsubishi.
The most common problem these sets have is called convergence. Go into the customer menu with the Mitsubishi remote and select convergence--enter the "advanced" and look at the grid of lines (set will have on screen instructions for this) Let me know more exactly what your picture looks like.
If you need more help or advice rate this solution as I do this here for Free. Reply here and I will help you.
Regards, SD TECH
Nov 27, 2009 | Mitsubishi WS-65909 65" Rear Projection...
My screen has a blue line that sags from the left side to the right. It is in the top 3rd of the screen. It is not a single thin line.
Your TV has bad convergence IC's. This problem needs a professional Tech to replace these parts. The average cost should be around $450. Call a factory authorized dealer.
Thanks for visiting FixYa, Big Irish.
Nov 21, 2009 | Mitsubishi WS-65909 65" Rear Projection...
My Mitsub. ws-65909 green power light turns on for about 3-4 seconds, then shuts off. Ideas ??
Replace Both of your STK ICs they are big black ICs will have # on them STK392-570? Call Mats for Parts 1-800-628-1118
Sep 24, 2009 | Mitsubishi WS-65909 65" Rear Projection...
I am buying a Mitsubishi WS-65909 from aprivate seller and I read
You have been mislead. I just checked the service manual and that model does not seperate in two like some Mitsubishi's do.
Apr 18, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WS-55809 dark scenes display green lines in background
the crt's pcbs need to be adjusted, screen control is not balanced
Nov 24, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi Daimond Series 65" Model#WS-65909
Most common repair is one or two open fuses in power supply
and bad convergence Ic's = expensive repair.........Also, have
the tech check for coolant leakage from CRT's...........T.
Dec 30, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mistubishi ws-65909 will not come on
I bought the mitsubishi black diamond gray 65819 is under warranty and had same problem , turns off like after 2seconds ,it can be fixed people but u need a sears tech, I had one come out and was told they no longer can get the part ,but he had to take it to repair it and yes its was a steal for me ,depending where u live the cost for me would have been $350 for part,$200 labor its the board that the power cord is connected to in tv... I live in s.a. texas , the unit that set up the service is 9905 ,the repair unit is just down the street from them off culebra so if u get tech says cant repair it this one does,it helps if u have the warranty or protection agreement
Dec 01, 2007 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WS-65909 65" Rear Projection Television Logo
142 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
