Question about Acer AL1916W 19" LCD Monitor
ACER AL1916 wont turn on
I powered it down the night before and this morning I get no response from the monitor, i tried another power cord and nothing. What should I do?
  • BOCHIE Jan 07, 2008
    i have the same problem. tried another power cord ,no luck. power lite does not go on.
  • ronjr83 Jan 11, 2008
    how do i check if the switch is ok?
    Champion:
  • 238 Answers
Hi, first aid... check if the power switch is ok on the monitor, and let me know how you confirm the switch is ok???
Posted on Jan 10, 2008
  • ravi chavan Jan 12, 2008
    hi, as u say that u had powered it down the night before, its very likely that the switch must be bad, u also have changed the power cord, so the only thing to do is to open the lcd ,if u can" to check the powersupply section, there must be either a fuse or a fusable resistor, check it out, if u have all the necessary equipments.U will have to check the power supply section very carefully.
.won't turn on. all plugs are in properly. has
When you turn on the main power socket to the monitor, does the front LED turn come on (Green/Orange)? If not, try changing the power cord or the fuse inside the power cord.
Feb 19, 2011 | Acer X183H 18" Monitor
My Acer AL1916 won't turn on. The power light is flashing, but besides that there is no response. This has happened several times, but I've always been able to 'fix' it by puling all the cables out,...
This is an indication that the monitor is not receiving signal from your video or graphics card.
You may try to connect the monitor into a known working computer to see if the monitor will work. And if it does, then the problem has something to do with the video or graphics card.
Try to open the case of your CPU (make sure that it's unplugged from the power source), unscrew the graphics card, pull it out from the slot, and then clean it using a clean cloth to remove the dust.
Then re-seat the card.
Thank you and good luck!
Jun 13, 2010 | Acer AL1916B 19" LCD Monitor
I booted up my computer this morning and my AL1916 monitor has a very red tone. I can't access the menu to change the display. What can I do?
Red tones are usually caused by a few things.
First try to reseat or use a differnent vga cable from your computer.
If that does not work, There may be a bad bulb in the lcd panel. (bad bulbs will show up red until they totally burn out, then the monitor wont stay lit.)
There is also a chance that the power board is getting weak and isn't putting out enough power to fully light the bulbs.
To check for the problem in the board or possibly the screen, the monitor would have to be opened up.
If you decide to try that and can send pictures of the boards, we may be able to figure it out.
bammbammfran from ebay
Mar 06, 2010 | Acer Computers & Internet
Acer AL1916 monitor wont turn on
normally along the number keys are cymbals, you must look for one that is a wireless sign, then i think you must press a key with this key to enable it, normally its a fn key
Nov 29, 2009 | Acer AL1916W 19" LCD Monitor
Acer AL1916 can't start
If you press the power button and nothing comes on at all then something isn't providing power to the laptop as it should and you may likely need to replace the battery or the power cord.
Find a replacement battery. Change your battery with a new one then plug it up and turn on to see if this works.
If replacing the battery doesn't work then replace the power cord and trying turning it on again. If this doesn't work either, you have a more serious issue going on.
Not too long ago, I was on vacation, my laptop had been working fine until suddenly it wouldn't come on at all. I went into the office to grab a new battery and power cord. (I work on computers so I had spare parts in my office/Tech Room.)
I got home and replaced the battery then tried to turn it on using the old power cord...didn't work. This was a brand new battery so now I knew that I could rule out the battery as the issue...the only two things left to troubleshoot were the power cord and the laptop itself.
I put my old battery back in the laptop then tried to turn it on using a different power cord and it worked. I didn't need to replace my battery or laptop. The power cord had failed.
I hope that your issue is as simple as this solution. Try confirming whether your battery and power cord are still working...you may just need to replace one or the other.
Thanks for using Fixya.
Share your experience by rating this solution.
Mar 29, 2009 | Acer AL1916B 19" LCD Monitor
Red tinting with the Acer LCD monitor AL1916
Amazingly enough my monitor did the same thing and while looking for the serial number the problem got resolved. Since I don't know exactly how it got fixed I will tell you what I did. I turned the monitor off, removed the power cord from the unit, turned the surge protector off and back on, placed the monitor face down on my chair to read the serial number, reconnected the power cord and turned the unit back on. The problem was fixed. Go figure.
Nov 16, 2008 | Acer AL1916W 19" LCD Monitor
Acer Flat Screen AL1916 A
hi ,first unplug the monitor both from mains and the comp, keep it that way for some time and then check, and secondly the clicking sound might be of the relays used in the power curcit, check the relays,let me know
Dec 26, 2007 | Acer AL1916W 19" LCD Monitor
Brightness issue
hi, try recycling the power, unplug the power and vga cable and leave it out for some time, then check.. let me know
Dec 05, 2007 | Acer AL1916W 19" LCD Monitor
Blank sceen
No, because it sounds like the backlight has blown. These LCD monitors utilize a backlight, just like the florecent bulbs we see in office buildings. Alot smaller! These things can be repaired, but by the time you figure out how and when you track down the bulbs you would have purchased a new for all of that time. But they can be repaired!
Nov 26, 2007 | Acer AL1916W 19" LCD Monitor
Monitor won't turn on.
it something that is defect in the power mian board. Try to seach any buldging capacitor. that might have problem you.
Nov 23, 2007 | Acer AL1916B 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
335 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
