Question about Bernina Activa 130
Bobbin Carriage clanking noise, yet the machine sews fine??
Bernina 130 Sewing Machine
While sewing, the needle broke off. I got both pieces of the needle so nothing is stuck in it. Then the bobbin carriage started making clanking noises. I took the bobbin case apart. Put back the hook and race and it still makes noise. It sews fine and the tension and everything is beautiful. But the noise is coming from the bobbin carriage (not the motor) and I don't know why. It's driving me nuts. HELP
  • Anonymous Mar 21, 2014
    where can i get a placement of this missing tension part. i took it for repairs 3 years ago N WHEN IT CAME BACK THE TENSION FOR THE COTTON part is missing and the person at bernina sewing machine centre refuse to place this part back and i have been waiting for 3 years now for him to return the missing part to me, please help me
  • Anonymous Mar 22, 2014
    tension is fine, makes clicking sound when sewing
    Problem Solver:
  • 6 Answers
If your bobbin area is making a noise, then do NOT sew with the machine until a reputable technician looks at it. You may have thrown something just a little off line - not enough to affect sewing NOW, but it could easily cause troubles down the line.
I suggest you call ahead and talk directly to the repair person - not to the sales person. Ask if you can bring in the machine while he/she is in the shop so they can listen while you run it.
You aren't trying to cheat the store out of the repair charge, just ensuring that the problem is diagnosed correctly.
You paid lots of money for this machine - it deserves good care.
Posted on Dec 30, 2007
My sewing machine was sewing fine until the needle broke and I changed the bobbin what did I do wrong
First, check to make sure you have threaded it correctly--upper thread and bobbin.
Most likely the sewing machine's timing was knocked out of alignment when the needle hit something, possibly a pin, a thick piece of fabric, the presser foot, or needleplate. Search for sewing machine timing or take it for service.
Jan 14, 2017 | Sewing Machines
Bernina activa 130 tension loose after needle breaking into bobbin area
Is it the bobbin tension that is very loose? Try tightening it. Also check that the bobbin has been installed in the bobbin case, turning the correct direction and that the bobbin tension is threaded properly.
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
If it is the upper tension that is loose and creating "thread nests" under the fabric, the machine is either misthreaded or possibly the thread is not seated completely in the tension disk.
Remove the upper thread from the machine.
ALWAYS RAISE the presser foot and rethread the upper thread from the beginning--verify the thread path is correct.
Set the upper tension to the midway point between high & low number (the factory standard--although it may need tweaking later for your particular machine).
Retest your machine. Hopefully, the issue has been resolved. If not, it may need service.
Tutorials Urban Threads Unique and Awesome Embroidery Designs
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
Oct 03, 2016 | Bernina Activa 130
Singer confidence 7470 while sewing the bobbing lifts up and makes a clanking noise the faster you sew. Any suggestions to this problem please?
It sounds like the bobbin is stretch. I fix mine taking a little screw driver (the one that comes with the machine) and turn the little bobbin case screw a tad to adjust the size of the bobbin carriage. Does the sound comes from the upper side of the machine or the under (bobbin) side of the machine? Did you oiled it correctly?
Nov 30, 2013 | Singer Sewing Machines
Clanking noise & won't sew
Are you sure you put the correct type of needle in? Normally, if you have any problem, cleaning and oiling will fix it. It sounds like you either didn't tighten the needle screw or you put the wrong type of needle in.
Jun 24, 2012 | Janome Sewing Machines
Thread jams starting with 1st stitch on Bernina 160
since a needle broke, & a new needle was put in, was the needle inserted correctly, normally flat side to the back of the machine, & pushed all the way into the needle holder
rethread the machine top & bobbin
make sure the bobbin is inserted correctly into the bobbin case.
if none of these suggestions help, then it's possible that when the needle broke it could have caused the machine to jump time & would have to be checked at a sewing machine shop
May 21, 2012 | Bernina Virtuosa 160
My bobbin case jumps out while I am sewing on my bernina 1008.
it sounds like the bobbin case needs to be replaced, have you cleaned under the needle plate & bobbin area for lint & loose threads
I also would suggest to take the machine to a different sewing machine repair shop.
Mar 05, 2012 | Bernina 1008
My sewing machine won't sew
have you checked the needle to see if it's damaged,,if not sure replace the needle--flat side to the back side of the machine--all the way up into the needle holder
is it possible that you wound a bobbin & the bobbin winder spindle was not returned to the left position
Feb 28, 2012 | Bernina Activa 130
I used the embroidery bobbin sewing and now it's not functioning
I do not believe the bobbin thread is the reason for the problem.
Refer to your manual for maintenance, especially cleaning the bobbin area.
When you replace the bobbin case be sure the needle is in it's highest position and this will also set the shuttle in position to properly accept the case.
If the problem continues, then machine will need to go into the shop. If the timing needs to be adjusted, this is best done by a Bernina tech.
Apr 28, 2010 | Sewing Machines
I broke a needle sewing some fleece that was too thick. I got all the pieces of the needle. Now it won't pick up the bobbin thread. Is there something else I can do or do I take it in?
I called the Bernina dealer and they said the timing was probably off and needed to brought in. 4-5 day turn around and about $70. That's if it doesn't need parts. The dogs don't get new halloween costumes this year. I don't have 4-5 days to wait.
Oct 28, 2009 | Bernina Activa 130
Sewing Machines Logo
1,005 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Wayne Buss
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
