Question about Mitsubishi WT-42313 42" Rear Projection HDTV-Ready Television
Green picture Our screen is predominately green. I have tried to balance the color using the remote, but it does not seem to help. Do I need a technician?
  • 373 Answers
I'm not sure about this model but most projection tv's have a focus/screen control block usually located behind the front grille where the speakers are. The grille usually comes off easily. If there are no circuit problems you can adjust the red green and blue picture tubes there. Also the focus. It will be written somewhere screen and focus: Three for screen and three for focus. If you find the screens then adjust them slowly clockwise for increase brightness on the red and blue and you may have to reduce the green. Adjust for best picture. If the picture does not adjust too good then the tubes are weak. Only if there are no circuit problems Hope this helps
Posted on Dec 30, 2007
Why does my TV have a green screen but no picture?
Single color predominant screen; is the fault. There are many reasons for this fault. It will be best to contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Probable causes are repair procedure to this fault "One color predominant screen" is given by one among the posts.
Apr 09, 2015 | Televison & Video
Why is the tv picture red?
Video output section circuit fault. This fault can be caused by many reasons, and called technically 'one color predominant screen'. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Mainly, loose solder terminals at the video output card can cause this. You have to look for it first. This car can be located at the neck of the CRT, will directly plugged to its back. Reasons for this can be read in detail by the above linked site. Surf it with type in "one color predominant screen"
Jun 15, 2014 | Emerson EWF2004 20" TV
Bush tv has blue colour on picture
Its white balance adjustment should be checked. Before doing this, check whether there is any loose solder terminals at its video output board. This board can be located directly plugged on to the back of the picture tube. One color predominant screen is the fault. Check this to know more about this fault.
Jan 08, 2013 | Televison & Video
Screeen color is green
This fault is called one color predominant screen. The cause might be to its video output card itself. There will be some loose solder terminals around the Green video output transistor. Check this card for any loose solder terminals. Just re-solder all the suspected solder terminals by applying a little more solder, without making any solder bridge short in between adjacent solder terminals. This card can be located at the neck of the picture tube [a rectangular board], will be directly plugged on to the back of the picture tube.
Dec 27, 2012 | Curtis-Mathis CM27101S TV
No color blue
HOW DO YOU FINE TUNE THE FINE TUNING THE PICTHER
Nov 25, 2011 | RCA HD52W56 52" Rear Projection HDTV
Displays green color image/screen
When did you get this message? It seems like you have set the White Balance of the camera wrong. Set it to Auto White Balance to eliminate this problem. Use Daylight White Balance when shooting in bright daylight so as to eliminate any color cast in the image.
Feb 04, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Color of pictures
image quality occuring after long period of inactivity of the printer oftenis caused by inks drying up or clogging either the nozzle or the channels of your printhead. to prevent this from happeniong, i suggest you do the maintenance first: deep clean and calibrate the printhead before you start using it if you havent used it for quite a while. you might be experiencing a printhead problem if the printer is printing predominantly in one color. you should try to visit thsi helpful website. the link ive provided below:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
it should direct you to the right recourse regarding your issue...hope this helps..ciao!!
Oct 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Bad color
Turn the color level all the way down and see if you have a good black and white picture. If your screen isnt black and white it should have a predominate tint to it. then turn the screen control for that color down to achieve the best black and white picture. then adjust your color level that should help.
Jun 13, 2008 | Mitsubishi WS-48311 48" Rear Projection...
Green screen on tv
Grayscale. Could be in the Screen trimpots of the focus block as well.
Need an ISF calibration and/or rebalancing of the Screen trimpots.
Mr Bob
www.imageperfection.com
Dec 30, 2007 | Mitsubishi WT-42313 42" Rear Projection...
Color
USING A CABLE OR SAT. BOX ?? IF SO CHECK W DVD
Sep 03, 2007 | iLO 2600 Television
Mitsubishi WT-42313 42" Rear Projection HDTV-Ready Television Logo
109 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
