Question about Bose Lifestyle 12 System
6 disk will not eject
I cannot get the 6 disk cartrige to eject, any ideas, it just makes a grinding sound like its going to eject but wont
  • 3 more comments
  • Anonymous Jan 15, 2008
    I am having the same problem. The disk is stuck with all 6 cds and can't find anyone who I can bring it too. Any suggestions?
  • Bob McCarthy Feb 23, 2008
    I have a Magnavox CDB 486 with the same problem. I took the cover off and re-tried eject. The belt on the motor that pushes the cassette forward is worn and loose. I put a little tension on it with a round nut driver shaft and tried again and it popped right out.
    Now I just have to find a replacement belt. Any ideas where to look? Above the model number on the name plate on the rear it says Consumer Electronics in Kentucky for parts, but I can't find that on the web.
    Square belts for CD Playerts - anyone know how supplies assortments?
    Ballast Bob
  • Asanka Wijeratne Mar 16, 2008
    I have the same problem that the 6 disk cartridge will not eject. The underside of the Bose lifestyle 12 system has a area with the wording:
    "manual magazine release" but no clear indication for what you have to do i.e. no buttens or anything visible to push/press/etc.
    Can anyone help?
    Asanka
  • den1964 Dec 27, 2008
    Can someone advice me on how to open the media to release the jam cd changer?
  • Bob McCarthy May 11, 2010
    I know exactly why mine is not ejecting. My request was for help in finding square belts for the drive mechanism, since putting a bit of tension on it makes it work perfectly. It's easy to reach and easy to replace BUT I can't find an assortment or the right size belt online. Some have suggested the Partstore.com, but I could'nt find them, may be looking in the wrong place. Any suggestions for drive belts for audio?
    Thanks,
    Ballastr Bob
    Scholar:
  • 48 Answers
You are all correct......
as are many other people with 6 disk cd changers in the same boat. check out this web site i have found at least 15 others with the same problem ( round about , but all problems relate to the 6 disk cd changer.)
the 6 disk changer is not excluse part to bose.
i recommend forcebaly removing the dam thing trying not to damage it further,( savge smashing the cd changer cassette) and trying to get a new one somewhere)
really though, you should consider surgury, - > open it and obtain spare parts to repair in the usual bodging fashion. ( that is to say any way you can ) or else return to manufacturer for remanufactured or replacement units at a cost or try to find replacement units on line such as ebay.
Posted on Mar 09, 2008
  • spongeboob Mar 11, 2008
    Hi Regarding the belts,
    that is likely to be indicitive of another problem,
    it seems unlikely that the belt will have stretched,, however it is likley that lubrication on motorised parts (driven) has become viscous, if you have it apart already, the existing lube can be cleaned with either spirits or specialised de greasing circuit board cleaner and cotton bud.
    if however you are sure belt is at fault, increase the diameter of the drive pulley with a very small rubber band and some some super glue if necessary and , this will provide an increase in the belt tension due to friction and the increased diametre.
    hope that is a more helpful suggestion.
What is the proben with an RBQ car disk player that came with a 2005 Jeep Liberty that wont load or eject the disks on a 6 disk player load or eject the disks?
check fuses
if good fuses, the deck is bad.
upgrade time. go diskless like all us.
we use flash USB sticks.
discs are dead. end of life and era. and weak tech.
i have 4000 songs on a stick , no CD no DVDs. zero.
buy any cheap media head end player and install it.
Aug 19, 2014 | 2005 Jeep Liberty
PRINTER MAKES A LOUD SOUND LIKE A MACHINE GUN WHEN IT PRINTS
Turn off the Printer
open the Front access Door, Check if there is bits of paper or dirt on the ROD that moves the Cartrige/carriage.
Move the Carriage freely 5-6 times from left to right ( it should move smoothly )
Remove the Cartridges, Clean the contacts on the Cartridge ( golden Contacts)
Open the Rear Access door, Clean the Rollers with lint free cloth.
Close the Rear access door and front door
Power on the Printer. If the grinding noise continues, Unplug the power cable from back of printer ( while printer is on ) and while holding the # and 6 button, connect it back.
It should go thru alignment process and the grinding noise should be gone. If it doesnt, probably.. its time for new printer of HP again.
Jun 24, 2010 | HP Officejet J5780 All-In-One InkJet...
'03 Honda Accord 6 disk changer won't load/eject
i had the very same problem with a six stacker in my ford, the stacker inside has come of its tracks even by one or two teeth so when the cd tries to eject it jams on the side walls because of this alignment, only way to fix is to take it out and realign. may need to get a mechanic or your dealer to do it like i did as the computer system was attached to my cd player. not sure about the accord but this is a familiar problem with all sorts of 6 and 10 stacker cd players
Jun 23, 2010 | Car Audio & Video
CHM-S630 6-Disc CD Changer: what is the best 6 disk cd player to connect to an...
hi how are you , my cd changer s630 recently just started to eject the whole cartreidge i push it back and its makes some nosies and then the same ejects it
May 18, 2010 | Alpine CHM-S630 6-Disc CD Changer
Cd error wont play or eject 3 of the cds in the 6
sorry unit is not servicable you can get a used one at many junkyards
Nov 12, 2009 | 2005 Dodge Grand Caravan
Car cd changer problem
cd changer not working in leganza
Jun 18, 2009 | USA Spec SCD-D50 6-Disc CD Changer
Wii makes a horrible noise while loading or ejecting the disc
Hello my name is Tim Ehrhart, I repair 360's and have had this problem with them and there problem is that the magnet that holds the disk in place gets stuck and makes a grinding noise that sounds horrid. Please leave feedback as I am new and trying to build a great rep. Thank You.
Mar 12, 2009 | Nintendo Wii Console
Malfunctioning DVD player
that is normal for laser to do that.
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Feb 03, 2008 | Cyberhome CH-DVD 300 DVD Player
I'm having a problem with my CDJ 800. Loading ejecting
Jan 28, 2008 | Pioneer CDJ-800 Turntable
Cd cartrige
Mechanical problems aside, you may have a pickup problem that needs professional help...accordianman
Dec 17, 2007 | Bose Acoustic Wave (32022) 5-Disc CD...
Bose Lifestyle 12 System Logo
765 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
