The ink level gauge may not work properly with refilled cartridges. Because of this, you might get low ink message after refilling. To install the refilled cartridge you might need to override the ink level gauge. Overriding the ink level gauge disables the printer’s ink level tracking feature, but allows you to use refilled cartridges. To override the ink level gauge, please check your printer reference guide. After disabling the ink level tracking feature you should check the ink level visually and as soon as the ink level gets low you need to refill the cartridge. You do not want to try to print with an empty cartridge. Trying to print with an empty cartridge may damage your print-heads.
otherwise you will have to replace the cartridge .
I have a Kodak esp 3. I just changed out the color ink cartridge, and despite having only printed 10...
(More)
I have a Kodak esp 3. I just changed out the color ink cartridge, and despite having only printed 10 pages total (none which were color) it says it's already out of color ink and will not perform any function. I still have plenty of black ink and only want to print b&w. Is there anyway to "trick" the printer into the thinking the color cartridge is full (which is still MUST be btw since i haven't printed color)? I had a Brother MFC once that you could put painters tape of the cartridge to trick the laser sensor into thinking it was still full. However, the kodak cartridges are black so that won't work. Any ideas?
getting a e light error on kodak esp3 printer...if I take 1 ink cartridge out one of the red lights...
(More)
getting a e light error on kodak esp3 printer...if I take 1 ink cartridge out one of the red lights goes away, this happens if I take the other ink cart..out the other goes away..but both in they are both red with e printhead error...
An error message has appeared saying the print head is missing, not installed correctly or has come...
(More)
An error message has appeared saying the print head is missing, not installed correctly or has come loose. it it telling me to remove the cartridges and printhead and then reinstall. i have done this about 15 times now and the error is still appearing. the cartridges are fine so i know its not that. ive tried switching it on then off as well!
loaded new firmware for kodak esp 3 all in one printer and now the black ink is not recognized. How...
(More)
loaded new firmware for kodak esp 3 all in one printer and now the black ink is not recognized. How do I go back to the old firmware?
