Question about Panasonic PT-52LCX65 44" HDTV
Panasonic display with no sync option
We have a new 58" display that has the option to switch between composite and RGB but when we try to go to the sync option it is grayed out and the colors are all messed up. How can we get the sync option to turn on?
    Genius:
  • 1,148 Answers
COMPOSITE IS LIKE ANOLOG RCA JACKS ,,RED,WHITE,YELLOW,,COMPONENT IS RED,GRENN,BLUE,,,PLUG EITHER ONES IN TO THE CORESPONDING CONNECTIONS ,,SHOULD HAVE ITS ON INPUT CHANNELS
Posted on May 15, 2009
KEEP GETTING MESSAGE ON TV (RGB ON TV SCART HAS BEEN ENABLED)
trouble shooting common problems when using RGB ...
https://www.retrogamingcables.co.uk/trouble-shooting-guide-for-rgb-sca...
No video or sound on tv when using RGB SCART cable. Check that the SCART socket you have plugged the SCART cable into is an RGB enabled port (this is ... Some TVsets display an 'RGB' message in the top right of the screen for a short ...
SCART - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/SCART
WikipediaThe signals carried by SCART include both composite and RGB (with composite ... A VCR will often have two SCART sockets, to connect it to the TV ("up", ... SCART enables a device to command the TV to very quickly switch between signals, ... The box can instead ask the TV to stop displaying the normal signal and ...
How to use your TV as a computer monitor for gaming, videos
www.cnet.com > Home Entertainment
CNETJan 26, 2012 - Many modern video cards have an HDMI output. ... The trick, of course, is finding a TV with RGB-PC inputs. ... You can also send him a message on Twitter: @TechWriterGeoff. ... (Or just enable game/graphic mode) ... As yet I've been unable to find anything online that lists TVs that do or don't work with PCs ...
Scart fully RGB enabled? ' AVForums
Feb 09, 2016 | Televison & Video
Missing red composite signal on panasonic pt-47wx52cf
Check your jacks and cables.
The RED jack is either (1) left or right channel AUDIO signal or (2) the RED color channel of an RGB (Red, Green, Blue) COMPONENT video signal.
Yellow is the COMPOSITE video signal.
Dec 31, 2012 | Panasonic PT-53TW54 53" Rear Projection...
I have a Toshiba 3387DB TV and am trying to connect it to my laptop. Tried to use DVI (out of laptop) to RGB phonos cable. Then through a scart adapter into the Scart 1 socket at back of TV. Manual says...
You need to convert the component sync signals into a composite sync compatible with SCART. The red, green and blue signals can be connected through as-is.
Mar 21, 2011 | Toshiba 3387DB TV
I have a Panasonic TX-P42VT20 and a SCART switching box from a number of devices (2nd Satellite receiver, DVD players etc.). This works fine with my old TV, but I only get sound and no video when I connect...
I expect the new Plasma is configured to RGB or S video. Check your menu settings and adjust to whatever the old TV was set at. Composite Video I suspect!
Feb 04, 2011 | Panasonic Televison & Video
I have a Sampo PME42x9 monitor that I am trying to get to work with my laptop. I set the input to RGB and hook it to the laptop and then use the Fn key with F8 and nothing happens. On the monitor it says...
The problem of course is not the computer since you communicate well when using the Samsung TV. The problem is your Sampo. The Video Ports are:
Composite Input (Shared w/ S-Video) RCA-pin x 2 S-Video Input (Shared w/ Composite) Mini DIN 4-pin x 2 Component Video Input RCA-pin x 2 Sets (Y/CB/CR, Y/PB/PR auto detect) DVI Input (with HDCP) DVI-D 24 pin x 1 RGB Input D-Sub 15-pin x 1
If the RGB WILL NOT COMMUNICATE, I suggest you try RCA/DVI/ or shared composite. You may need adapters, but with so many options, just try other methods.
Feb 06, 2018 | Sampo Computers & Internet
Can't connect my mac mini to my television
How are you connecting? Do you have an RGB connection on your TV? There is RGB cables that convert too DVI or Composite. Check your local computer store.
Jan 29, 2009 | Sony PlayStation Portable (PSP) Console
S-video problem on Panasonic TV
Have you tried another S-Video patch-cord?
Some cheaper ones short across pins.
What output from DVD are you using?
If composite video 'Yellow' RCA socket, a cheapo cable can also create sync problems ie signal timing, causing patterns on screen.
The S-Video is actually 2 signals - one for Chroma C and the other for Luminosity Y. With S-Video to S-Video connections, this gives better quality than composite, as each line can handle separate voltages, levels and frequency for Chroma = pixel color and luminosity = pixel intensity.
Composite has to cram all this info onto one channel, so signal quality is lower than S-video.
A hack that videophiles use is to place a 470nF ceramic capacitor across the 2 signal pins, instead of the cheaper just bridging them together.
This apparently helps to re-sync the combined signal from composite.
A tester on ohms and steady hands can test whether your cable is cheap-shorted type, or better synced type.
Across C and Y pins:
0 ohms=shorted
high reading or open=small sync cap
If making own cable mod:
Pins are closely spaced, so easier way is to strip and dress cable near S-Video plug, solder wires to cap accordingly, join composite to cap & Gnd as shown, insulate.
Nov 20, 2017 | Panasonic CT-36D31 36" TV
TV ranking
Hi. You could look up reviews. I personally usually never offer advice on choices, because what I like, may not be what you like..its a matter of personal preference. But in this particular case, I'd go for Panasonic. Why? Better features, better service, easier availability of parts, and better resolution.Plus some nice features. If this answers your question, PLEASE don't forget to rate as fixed. I'd really appreciate it. Enjoy your new tube!!!
Jeff
May 12, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Jan 13, 2008 | Daewoo DV-6T955B DVD Player/VCR
Video output from VHS recorder
does your television have multiple scart connectors? Sometimes some models have only 1 connector that will accept RGB signals... Another thing you can check are VCR settings - scart component video output is not "official" and hence you might need to look at some of the setting if you need to enable it. Another possibility is that your scart cable may not have your rgb signals connected (based on wikipedia reference: "not all SCART cables make use of all the pins, often leaving out RGB signals. In many cases there is also no way to see which type of signal that is currently displayed on the TV set."
May 05, 2007 | Zio Corporation CameraMate RealTime...
Panasonic PT-52LCX65 44" HDTV Logo
55 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
