Question about Maytag MDG2706A Gas Dryer
Maytag Gas Dryer SDG515DAWW - heating stopped
This Legacy Series dryer has worked fine for about 4 years, but today it stopped providing hot air. All electrical works fine, and drum turns. I checked the igniter and it does not glow hot.
Is there a good way to check and see if the problem is with the igniter versus the thermostat versus something else? I would like to try and order the correct part the first time.
Thanks
Bruce
  • swandog99 Dec 31, 2007
    Replacing the igniter did the trick.
    I also found the thermostat and learned that this is also easy to check (check for continuity with my ohm meter).
    Thanks for the tip.
    Bruce
  • chas_italia Jul 01, 2008
    my dryer stopped heating today i looked at bottom the glow mech lights up but no gas openens
    President:
  • 1,314 Answers
If it dont come on in 30 secs replace it
Posted on Dec 30, 2007
Sdg515daww maytag legacy series gas dryer will not put out any heat until the dryer has been on for about an hour or an hour and a half...have cleaned external vent tubing and vacuumed (as far as vacuum...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Dryers
Model sdg515daww dryer working but gives no heat.
heatman101
Jun 18, 2011 | Maytag Dryers
MAYTAG LEGACY DRYER IS 3 YRS OLD TODAY AND HAS STOPPED HEATING. BREAKERS ARE NOT TRIPPED AND PROPER VOLTAGE AND VENTING IS WORKING PROPERLY. HOW HARD IS IT TO CHANGE THE HEATING ELEMENT? THANKS FOR THE...
heatman101
Apr 23, 2011 | Dryers
Dryer stopped heating
watch the video
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 11, 2009 | Dryers
2 year old maytag gas dryer blowing warm air
Hi, Is there ant heat at all? Is it possible the dryer heats at first and stops later in the cycle? The first thing to check is the 4" vent going to the outside. Make sure it is cleared of lint and that it is not pinched off at all.
If the vent is ok, you might need to replace the coils on top the gas valve.
I can help you with this. I just want to narrow it down.
Vic
Jul 05, 2009 | Maytag MGD9700S Gas Dryer
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the igniter
a%20igniter.jpg Igniter and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 03, 2009 | Dryers
Gas Dryer
HI thanks for your question. the problem is with the coils on the gas valve. one has failed. they come in a pack of 2 replace the coils. thanks the appliance doc. please rate my answer. thanks.
Oct 14, 2008 | Maytag Dryers
Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Jan 02, 2008 | Maytag MDG2706A Gas Dryer
Maytag MDG2706A Gas Dryer Logo
1,387 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
