Question about Dryers
Noise from timer occurs on ocasions when dryer won't start
Our dryer is an antique GE dde 5300 gblwh. It works okay most of the time, but occasionally when we set the timer prior to throwing the start switch, it will emit a noise. When this noise occurs, we know it won't start. I would like to repair this problem, and I would like to know whether it is a short, or something wrong with the timer.
  • 1 more comment
  • mteddybear Dec 30, 2007
    The sound is a buzzing type, coming from the timer area. Noise ends when door is opened, or when timer is turned off. I beleive the noise is from the timer, perhaps a short or something.
    Okay... I just wasn't sure if it would fix the problem. I will go find one online, and let you know if it takes care of the problem. Thanx for the help.
  • mteddybear Jan 08, 2008
    Found out that the main motor needed to be replaced. Found out when I tried to spin the motor by hand when the noise was occuring.
    President:
  • 1,314 Answers
Well lol its hard to bury an old friend lol will try to help what kind of noise are you hearing sure you dont want to get six of your friends to carrey it out lol tell me as much as ya can
Posted on Dec 30, 2007
  • robert samples Dec 30, 2007
    Well sorry to say but you need to replaced the timer. Last time I checked GE still had some in stock.
    hey your welcome
We have a General Electric Dryer, Model # DDE 5300 GBLWH.WE KEEP GETTING WHAT LOOKS LIKE OIL STAINS IN THE CLOTHS .IT NOT THE WASHER THATS A GE TOO .
There could be some rubber/plastic or other contaminants in the drum, that leach on to your clothes when the dryer heats up. It's possible that some oil got on the felt seal that goes around your drum.
Nov 15, 2015 | GE Dryers
Service manual for GE DPSR473EW0WW dryer
the timer may be stuck at a certain place as they have points that at times tend to burn out and stick when the timer gets to that point. do the other settings work? some times the moister sensor will not sense dry clothes and keep running? as for ur drum noise that may be due to bad rollers or bad tensioner and belt depending on ur model and hopefully not bad bearings also a possibility
Jan 22, 2015 | GE Dryers
My GE Model DDE 5300 Dryer leaves grease marks on my clean clothes. Is this any easy fix or is it time to buy a new dryer?
Probably dried grease that came out of a worn out bearing. With it's age it's time for a new one.
Feb 23, 2018 | GE Dryers
GE dde 5300 dryer overheats.
You need to replace the "cycling thermostat" on your unit. Here is the part to order.
The thermostat is located at the back of the drum on top of the heater assembly.
Nov 24, 2012 | Dryers
Our DDE 5300 GBLAD dryer makes a rumbling, thunder-type noise after it's been drying clothes for awhile. What is wrong?
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them then you will need to replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
May 15, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
My 1987 GE Dryer, Model # DDE5300GALWH,will not run all the time.
sounds like you need a new timer you can actually take the timer apart to check for a burnt connection
Jan 07, 2010 | GE Dryers
Squeal noise from the dryer
check the belt tention. or you may need to lubricate the wheels the drum sits on.
Jul 16, 2009 | Dryers
Dryers Logo
124 people viewed this question
Top Dryers Experts
Marvin
Marvin
