Question about Hitachi VMH665LA Hi-8 Analog Camcorder
Dropped my camcorder onto carpeted padded floor.
Everything seems to work except when i'm ready to record, there is nothing in the view finder. I can playback what i taped in vcr mode but when i record even though i can't see what i'm recording, it's all black in playback mode. Anyway nothing is rattling and everything else seems fine.
Noggin
  • 944 Answers
SOURCE: Trying to copy camcorder tapes
If you really value the material, then the best thing is to transfer it to a digital media rather than VHS. various digital media can be almost indestructible, whereas vhs tapes will eventually die, depending on the quality of the tape and the temperature / humidity in which they are stored. There are a few options for doing this. If you have a PC (or Mac) then there are numerous analog to digital video converting devices and software. First you need a video input/capture card in the computer, then software often comes with these. Otherwise windows movie maker, which I believe is bundled with windows XP service pack 2, apparently works for basic procedures. Have a look at this link - I haven't tried the item myself but it looks good for the money and has had good reviews; http://www.amazon.com/ADS-Tech-Video-Xpress-USBAV-191-EF/dp/B0009UDABW But there are many different ones. Another option is to use a professional studio to digitize your tapes - they are normally quite expensive because although the operation is not particularly complicated, it can be very time consuming. http://tech.yahoo.com/blogs/hughes/194 check this link for more ideas. As to the fast-forwarding issue, I have no real solution, but you should be able to edit this digitally easily enough. I suspect a fault with the camera, probably an overheating issue, but maybe as simple as a worn internal switch. tape faults are also a possibility. The age of the camcorder would suggest that it is probably not worth fixing, if you would like to try though please post again. My advice - go digital, get a studio to do it, use a good one and your footage will be preserved for ever in near perfect quality. The longer you leave it, the worse the tapes may become. else if you want to do it yourself, follow the first link and hunt around for other hardware - any problems please ask. Hope this helps :)
Posted on Mar 26, 2007
techman
  • 3130 Answers
SOURCE: Transferring camcorder tapes to VHS
It depends on what speed these tapes were first recorded on. Maybe the camcorder your trying to use to play them back do not support this tape speed I have seen this in the past. Are these 8-MM or VHS-C tapes.. Also the tapes that were recored, maybe tyhere was something wrong with the tape path and was slightly out of alighnment. I had once a Sony 8-MM camcorder and tapes a lot of stuff and then gave them to someone to watch and they would not play. I tryed the tapes again in my camcorder and they worked great. I got a test tape and tryed it in my camcorder and it turned out the tape path alighnment was off, so i had to rerecord everything I had from one camcorder to DVD so i could fix my camcorder. Good Luck
SOURCE: Camcorder "Freezes Up" during playback and/or during creation of thumbnails
I had the same problem - you are (as I was) turning off the camera too soon after you hit the stop button after recording a scene. Wait until the word "disc access" appears (about 5 seconds after you hit the stop button. This "marks" the end of the scene. I just don't know how to edit that scene out or if it will delete it out. I know after finalizing the disc that scene will pause for a while (10 to 20 seconds even) when you watch it through the DVD player to the TV.
Posted on Oct 06, 2007
issy2
  • 462 Answers
SOURCE: flashing tape!
this is because there is lot of condensation taken place inside.. so keep the eject tray open and most important in a clean dry place say atleast 3 to 4 days...
Posted on Aug 03, 2008
SOURCE: Sorry to be a nuisance...but I really need help!
ihavedzmv550e becuse imissed my software cd
Posted on Aug 09, 2008
The tone arm drops onto the record, but then continues moving across the record without playing the record. Anyone know what's going on?
Does the needle actually contact the record? If not, you may be missing a "pad" under the record, or you may be simply missing the needle that needs to be there to follow the grooves.
Nov 02, 2014 | Audio Players & Recorders
The lcd screen on my hdr cx-150 is not working but can still record and take pics, how do i fix it?
hi,
does the view finder work ?
if yes, there must be the flat ribbon cable that may have been moved and disconnected, but if the view finder doesn't work too, there must be a board inside or a connector that has been moved (connectors a sometimes sensible to chocks, an in between the boards there are connectors too...) the LCD controler-processor board for exemple.
cheers
mich
Mar 03, 2013 | Sony HDRCX150 Camcorder
Hello... My camcorder is a handycam video 8 ccd-tr440 ntsc and everything works just fine except for the image in the color view finder, i can see the battery status and everything else except for the...
http://www.digital-camera-battery-charger.co.uk
http://www.battery-charger.us
We are committed to the laptop battery, digital camera batteries, camcorder batteries, PDA batteries and Chargers, development, production and marketing services, the products sell well not only 11 years in Europe, America, Korea, Taiwan, Hong Kong and Southeast Asia and other countries and regions, but also through all major cities across the country to establish a sales agent in the form, the establishment of a comprehensive sales network and after-sale service system, the first class products and perfect after-sales service to consumers.
Nov 05, 2010 | Sony Handycam CCD-TR87 Camcorder
Cannot load a tape into camcorder. I have tried two separate tapes, neitehr of them load in to the camcorder. A message comes up: "remove the cassette" when it has not even been loaded properly.
I had the same problem. Checked the site and found a solution of dropping the camera onto a carpeted floor from about 1/2m to 1m. Thought that it was bullsh1t but was desperate and so tried it. worked a treat!!!
Hope this helps.
Jul 14, 2009 | Canon DV-MV830i Mini DV Digital Camcorder
Supercam ah dp800h powers on but nothing in the view finder
most likely problem is many defective capacitors on the video board.
Mar 02, 2009 | Panasonic AG-DP800H Camcorder
Nothing but a blue screen...ugh!
buy a cleaning cassette and play three times it will work well.
Oct 12, 2008 | JVC COMPACT VHS-C CAMCORDER
The view finder does not wotk
Try pulling out the eyepiece, it will reveal a switch that controls the focus, it maybe the problem, good luck
Aug 13, 2008 | Panasonic Palmcorder PV-DV351 Mini DV...
Nothing appears in view finder or on screen when recording
I HAD THIS PROBLEM ERROR CODE C31 : 22 WOULD COME UP AND TRV 118 CAM WOULD NOT WORK. I TRIED EVERYTHING TILL ONE DAY I BANGED IT ON A CARPETED FLOOR ON THE BOTTOM OF THE CAMCORDER 5 TIMES QUITE HARD. THEN THE CAM WORKED JUST FINE! MY CAM HADN'T WORKED FOR OVER 7 MONTHS. NOW I HAVE IT BACK. HOPE THIS HELPS SOMEONE.
Jun 18, 2008 | Video Cameras
JVC compact VHS camcorder will not record.
Apparently this same problem exists on many different models. I have a JVC grd72u. I called JVC @ 800-252-5722. I selected the "Corrective Action Program" prompt from the automated attendent. I spoke to a customer service rep. They are aware of the problem and are fixing it for free, but only until 12/31/07. I suggest you call ASAP and get your name in the computer. If the problem is something besides the CCD sensor, they will call you with the estimate to repair.
Nov 03, 2007 | JVC COMPACT VHS-C CAMCORDER
NO picture - JVC GR D74
JVC GR-DVL9500
Error Code E04 when I load a tape .
Oct 04, 2007 | Video Cameras
Hitachi VMH665LA Hi-8 Analog Camcorder Logo
Top Hitachi Video Cameras Experts
Mohamed Ismail
Mohamed Ismail
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
