Question about Mitsubishi VS-5077/78 TV
Front freznel lens cracked
Mitsubishi VS-5077 projection TV front fresnel lens cracked. Can I get a replacement?
    Genius:
  • 1,153 Answers
Vancebaldwin.com
Posted on Mar 26, 2008
Mitsubishi hdtv 1080 ws-a65 screen broke need replacement
there are 2 functionality screens and 1 screen protector (on some)
front screen = lenticular
back screen = fresnel
very front screen = screen protector (you can replace w plexiglass)
the fresnel and lenticular are very specific.. contact your local repair center for a new one. you can cut them from old screens but have to do just right (fresnel is a lens type - pic will be distorted if off center)
maybe find a old junker tv to pull screens from because new ones are about $100 a piece
Jun 03, 2010 | Mitsubishi WS-65311 65" Rear Projection...
NEED FRONT SCREEN THAT FITS OVER SCREEN
I'm trying to remove the screen from mine, do you have an owner's manual that shows how?
Jan 12, 2010 | Mitsubishi VS-60707 60" Rear Projection...
I require the front screen for Toshiba Rear Projection colour TV Model 43V J33Q
you have two screens. a fresnel and a lenticular lens. they are expensive but easy to install
Nov 09, 2009 | Toshiba 42H81 42" Rear Projection...
TV works fine for a while, then the picture disappears.
I would just replace the TV, the parts are not going to be made to repair this. The set is just to old.
May 12, 2017 | Mitsubishi VS-5077/78 TV
Just cracked my brother's tv screen when accidentally threw the Wi controller. TV is a 2005 Samsung DLP Model# HLR5667WX/XAA Will replacing the screen really cost as much as a new TV? I think it is a...
The good news is it won't cost as much as a new set! Why? because he has a DLP model, not LCD.
It has two screens, one is called the Fresnel and the other Lenticular. Each one is about $180.00, none of my distributors have them so that's the bad news. I will give you the part numbers and start doing your homework.
Lenticular-- BP67-00183A--Rear
Freznel -- BP67-00183A--Front
Jun 13, 2009 | Sony BRAVIA KDL-46V3000 Television
Mitsubishi screen replacing
You must remove the front bezel and frame holder to replace the screen. You will usually see the screws holding the from from the rear of the unit. Once you get the frame off, take note of the way the old screen is installed. There is usually a label on one side near the bottom; the new screens must be installed with the label in the same location. The lenticular goes on the outside (facing the viewer) and the fresnel goes on the inside facing the mirror. You will be able to recognize the fresnel, it has a series of concentric circles that are raised on the sirface of the plastic Be sure to rate this solution.Thanks!
Nov 08, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Mar 11, 2008 | Mitsubishi WD-65731 65" HDTV
Image problems
this might sound odd but you might have a bug or something on your mirror or have you bumped the front screen? the freznel and lenticular screens could have seperated. i would contact a local repair shop for an in home service call just to verify these 2 possible scenario's.
Mar 13, 2007 | Mitsubishi VS-60601 60" Rear Projection...
Lenses
The screen with the "swirls" on it is the fresnel lens and that is the one that goes in back then the lenticular lens goes next (it has the feel of a grid to it). Then the screen proetector goes on the very front. The fresnel lens only works installed one way. On Sony TV's look for the orange tag with the part number on it and put that to the lower right facing outword and usually 99% of the time this is how they go back in.
Feb 18, 2007 | Sony KP-51WS510 51" Rear Projection...
Televison & Video Logo
139 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
