Question about Dryers
Dryer drum won't turn
I have a frigidaire model FER211AS2 and the drum won't turn at all,not even by hand.The belt is not broke and the motor is turning.When I try to start it it makes a humming noise and the drum kicks a little but will not spin.Please help.Thank you.
  • 1 more comment
  • supermiss Jan 03, 2008
    drum will not turn on Kenmore 110.76662500
  • Anonymous Mar 15, 2014
    comes on dont start and d o is displayed can move drum a little by hand dont start or try
  • Anonymous Mar 22, 2014
    gets hot won't turn not even with my hands
  • 1,314 Answers
Bad rear bearing in drum
Posted on Dec 30, 2007
HIGH PITCHED dryer SQUEAL but clothes are drying...
Had same problem that went away after replacing each of the drum roller wheel/bearing assemblies. ( Not the easiest of jobs removing & replacing the drum, but a lot cheaper than a new machine.
Nov 23, 2013 | Frigidaire Washing Machines
You need to check the belt around the outside of the tub that turns the tub, the tention pully and the motor. is the belt broke? loose? motor turning?
Aug 17, 2012 | Dryers
Fridgaire dryer model #FDEC216RES1 drum isnt turning
If the dryer does not turn then you need to take the back off and see if the belt has broke or come off. If the belt broke or came off then you can get a new one at most home repair stores. If the belt is on and or not broke the see if the wheel mounted to the motor will freely spin. If it does spin the make sure that the electric wires attached to the motor itself are attached and there are no shortages from the motor to the relay on the back of the control panel.
Jul 03, 2012 | Frigidaire Electric Dryer
The dryer is plugged in and the circuts seem to work however the dryer is making a humming noise but it will not turn on fully.
what do you mean it won't fully turn on?do you mean the motor won't run because usually when it humms you either have a bad motor or something is jammed and stopped the motor from spinning.try this,open the door,with one hand hold the door switch in and with the other hand spin the drum,have someone else push the start button while you do this,if it starts the motor is bad,if you can't spin the drum something could be stuck in the blower wheel or the belt broke and could of jammed up the motor but it sounds like you have a bad motor.let me know what you find and next time send the brand name and model number.
May 04, 2011 | Dryers
I have a frigidaire gallery 49012/59012 dryer and the drum want turn. The belt is not broke and the motor runs. I can see the belt is not turning on the drum. Is the belt maybe stretched or what?
You may have a belt motor problem. Turn the drum by hand and if it turns freely the belt is off at the motor pulley. You can try to connect it back on the motor pulley but what caused it to come off first off. Your belt may be bad or the pulley assembly may also be bad. You'll have to pull out the dryer and remove the back panel to see and repair. Good luck.
Jun 28, 2010 | Dryers
Frigidaire sensor gas dryer will not turn on, power supply and breakers ok, Makes a noise like it wants to turn on. Drum is free and moveable.
if you can move the drum by hand and it's humming it sounds like you have a bad motor or the belt broke and is jamming the motor and that's why the drum moves,you have to get in there and check it out,open the door and the model number should be there,next time send model number
Apr 13, 2010 | Frigidaire FGQ332ES Gas Dryer
When Turned on, drum will not spin?
if the motor is running,your belt is the problem.if all you hear is a slight humming noise,you may have a bad motor,or something caught in blower. if the drum turns easily by hand,its probably the belt
Mar 05, 2010 | Frigidaire GLER341A Electric Dryer
Frigidaire FER211AS2 dryer drum belt
the washer has to be tipped forward. can access from bottom (and back).
Jun 03, 2009 | Frigidaire FER211A Electric Dryer
you will have to take it apart to get the drum out. you have to take the top off
May 06, 2009 | Dryers
It sounds like the belt broke off. Unless you have replaced even just the belt before,you need a experienced repairman, trust me.....
May 30, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
593 people viewed this question
Top Dryers Experts
