Question about LG VX8100 Cellular Phone
Can't turn off the car kit option.
I can't hear anything and my display says that the car kit is on, how can I turn it off.
Please help
  • 2 more comments
  • archstud09 Jan 07, 2008
    Car kit has been turned on and I don't know how to turn it off.
  • Anonymous Mar 02, 2008
    car kit is on. can not hear anyones voice or ringback tones
  • Rebelde0108 Sep 09, 2008
    cant hear anything and it says car kit mode
  • jkawalski Jan 13, 2009
The problem is in the port where you plug in the charger.. one of the little pieces inside there is broken or out of place... try GENTLY messing around with it with something pointy..( I just used a big pointy knife) With mine it was the last little poky thing in there that was frayed... it works fine now tho... Good luck...
Posted on Mar 03, 2008
  • Moester44 Feb 02, 2011
    Works fine after removing lint from recharger port. Thanks!
I want to thank you a bunch I almost bought a new phone I used a old dry toothbrush and it worked great
THANKS
Posted on Jan 16, 2009
^^^ Thats what I did, it fixed the problem immediately!
Posted on Aug 28, 2008
The *dry* toothbrush trick worked perfectly. My phone had some blue / green / turquoise colored buildup in the charging port. As soon as i brushed it out, the car kit option turned off !!! PERFECT!
Posted on May 13, 2010
The light in the display area on the top of the oven is out. We can not read the display as to temperature, etc. Oven still works. Controls beep when pressed, Just can't display anything. Thanks, whm
Welcome to FixYa.
The issue with these displays is they lose their intensity over time because of the fluorescent tube technology they use, hence the only remedy is to replace the control/display kit...the display only is not available.
You can find these "display kits" at "repairclinic.com" and similar to what I've attached here...
**Your other option, and the one I recommend, is to have the existing display and control rebuilt...the down side is this will require the parts to be removed and sent away**
Here you'll find all the info pertaining to this option by clicking on the link I've provided below
http://www.corecentricsolutions.com/CCSWeb.nsf/published/bosch
Hope this helps move you forward. Let me know if I can assist you further and good luck.
Regards,
Macmarkus :)
Feb 09, 2011 | Thermador SC302T Electric Double Oven
I have a tv/dvd flatscreen televsion. It is only a year old. The problem is I can not hear anything. My television is displaying the screen and movies/television is working fine, just no volume. Please...
Does the the little bar graph on screen volume display react when you turn the volume up and down or does it say something like TV VOLUME IS FIXED?
Try using your remote to look in your tv's MENU for the AUDIO OPTIONS.
Check to make sure the SPEAKER option is turned ON.
If that doesnt work, try running a cable from your tv's audio out jacks in the back to one of your home stereo's AUX inputs and see if you can hear the tv through your stereo.
Good Luck.
Jan 20, 2011 | Televison & Video
I have a 2009 Ford F150 2wd. I added a 2 1/2 leveling kit with 34 in tires and 20 wheels. When I turn it makes a sound like its rubbing. I eventually took it to a brake service center and was told that...
first check its not the tyres rubbing on the mudflaps/wheelarch.or even the inner wing(fender)YOU NEED TO GET SOMEONE TO TURN THE WHEEL HARD OVER WHEN YOUR UNDER THE CAR TO SEE WHATS TOUCHING.......the abs/electronics is just garage ********......
Sep 28, 2010 | 2004 Ford F150
I have this monitor - ViewSonic VA712 and when i use it, turn the PC on, the monitor power status light turns green, then display turns absolutely black (still the power status is on GREEN). Can hear from...
Very common problem with Viewsonic and all other brands of failed moniotrs is due to bad caps as you can see here:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find for further help.
Sep 04, 2010 | ViewSonic VA712 17" LCD Monitor
Aquiring Signal displays for 5-10 minutes before hearing audio
It's a bad Sirius tuner. You can find them on ebay for 50 or so rebuilt and they are better than new. It's cold solder joints on the antenna input plug. Hope this helps
Jun 17, 2010 | JVC KT-SR2000 SIRIUS Radio Receiver with...
My ck3100 has froze,
power to kit needs to be stoped, try removeing the radio fuse then attach again this should reset it
May 30, 2009 | Parrot Hands-Free Car Kit with LCD Display...
LG5000 cell phone mode
try to turn off computer,remove battery and turn it back on
Oct 10, 2008 | Cell Phones
Motorola BTHCK 100 car kit
hi ya bthck100 i can hear them in car but they cant hear me thanks dave help needed please
Sep 12, 2008 | Motorola Mobility Universal Bluetooth...
Parrot CK3100 Bluetooth Phone Kit
how do I clear full memory from parrot blue tooth phone system
Jun 20, 2008 | Parrot Hands-Free Car Kit with LCD Display...
"Car Kit"
this model do that when it get wet if that the case there is nothing to do but chage the board, go to the celu store they have jonk to fix these for about $25.00 more or less..good luck
Aug 06, 2006 | LG VX6000
LG VX8100 Cellular Phone Logo
1,386 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
