How do I install brushes on Hoover V2 Windtunnel? Does a right and left go on the right side and vice versa on the left side? That is how it orignally came? Or do I put both rights on the right and both lefts on the left?
The brush wouldn't work when the selector switch was in carpet mode. Took the power head apart and...
(More)
The brush wouldn't work when the selector switch was in carpet mode. Took the power head apart and removed the motor. Everything o.k. in the power head. Checked and found that the neutural wire had pulled out of the connector, the connector was never crimped at the factory. What a day! Took 2 hours and a large pizza to get it done. Neutral wire was in the hose just below the handle. Reconnected the wire and crimped it, put everything back together. It works!!!!
Need directions - how to use the wet vac feature? I am referring to the B&D Spillbuster...
(More)
Need directions - how to use the wet vac feature? I am referring to the B&D Spillbuster plus hand held vac. Thanks
