Question about Singer CG754 Mechanical Sewing Machine
Stiches skip I have threaded the machine exactly as described but I still don't get the proper stitching. Nothing sews
  • Anonymous Mar 22, 2014
    stiches not forming machine is threaded
    Problem Solver:
  • 6 Answers
Things to try:
1. New needle.
2. Make sure the needle is put in the correct way (there are fronts and backs to the needles).
3. Make perfectly sure that your bobbin is put into the bobbin case correctly (the thread going clock or counter-clock wise as indicated in the directions)
4. Make sure your bobbin thread is wound through the case and out as indicated by the directions
(these points vary DRASTICALLY by model of machine and brand).
5. Holding about 4 or 5 inches of top thread, rotate the flywheel (on the far right of your machine) by hand (don't use the footpedal). The needle should go down, it's thread creates a loop, and the bobbin thread loops through that loop; as you continue to rotate the flywheel, the needle will come back up, bringing its own thread AND the bobbin thread. This is when the machine is ready to sew (when both threads are up).
6. If your machine has been moved around and not very gently, then it is possible that the bobbin case and housing have been jostled out of alignment. If that's the case, then you'll need an experienced sewer to look at it for you - mostly that's a case of minor adjustment.
If you remember that the needle is flying up and down thousands of times in a minute, then having all these elements in perfect alignment makes sense.
Even experienced sewists get stumped with this, especially when working with a new machine.
Posted on Dec 30, 2007
Why does the stitches skip when I'm sewing?
Needle old or bent, incorrect size. Incorrect thread for material, packed with lint. The sewing foot is not on correctly or the needle is not pushed in high enough. Old thread. Hope this helps.
Aug 19, 2017 | Sewing Machines
My machine is skipping stiches it seems its not picking up from the bobbin
Install a brand new needle and confirm it is inserted with the flat side facing the proper direction.. A bent, damaged needle will sometimes cause skipped stitches or even needle strikes inside the machine. A new needle is the least expensive cure for a lot of sewing machine problems. The needle should be changed about every 8 hours of sewing or at least when starting a new project.
Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Sometimes, skipped stitches will occur if the needle, thread, and fabric are incompatible. Be sure to use the correct needle for your project. Use a good quality thread--AVOID old or bargain bin thread!
If the machine continues to skip stitches, then it may be out of time. Search for sewing machine timing or take it for service.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
May 24, 2017 | Sewing Machines
Skip stiches
Changing the needle may be helpful. A bent/damaged needle will tend to not pick up the bobbin thread properly.
Try a different type of thread--avoid old or bargain bin threads.
Could also be an incompatibility of the needle, thread, and fabric.
All About Needles
If it still skips stitches, then it may have a needle/hook timing issue that would require service.
Aug 19, 2016 | Sewing Machines
How can i fix this please.
Be sure to install a brand new needle. Bent/damaged needles will often cause skipped stitches. Also, make sure to use the correct needle for the thread and fabric. AVOID old thread or thread from the bargain bin. They are cheap and there's a reason why they are...
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwiG3KCum8nNAhVO8WMKHVvWD8oQjBAILDAC&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q&cad=rja
All About Needles
Jun 27, 2016 | Sewing Machines
Thread tension will not adjust.
Check your setting, you have your stitches set too far apart. Wherever on your machine you see the zigzag stich you will see other stich settings, look at it until you see the right amount of stiches you want.
Mar 06, 2017 | Brother CE8080PRW Limited Edition Project...
Top thread keeps breaking during sewing. Tension adjustment does not solve the issue. Also, machine is skipping stiches and will not sew anything but a straight stitch: needle moves in the ziz=zag or...
This could be more than one issue, first I don't think you have the machine threaded correctly. Make sure when you thread that the thread is seated betweeen the tension disc on the top and also, make sure that you have properly but tin the bobin
Aug 13, 2010 | Husqvarna Sewing Machines
Singer CG754 Mechanical Sewing Machine Logo
123 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
